Quantcast
Author Topic: KZ 750 Twin - Two point zero  (Read 65817 times)
Offline Brodie
  • Gold Coast, Queensland
Re: KZ 750 Twin - Two point zero
« Reply #250 on: Mar 12, 2017, 06:25:21 »
The c5 ignition for the Virago is driven off the cam, I wonder if the KZ could have the kit adapted.
Also there is a fair bit of discussion in using a VOES to control the timing maps with these. They are a nice bit of kit indeed
Offline beachcomber
  • TJ - Beachcomber
« Reply #251 on: Mar 12, 2017, 10:52:47 »
As ever, thanx for the info guys - sorry to bust in CC.
Offline canyoncarver
  • 'hacking is learning'
« Reply #252 on: Mar 22, 2017, 23:01:29 »
Never a problem BC, glad to have both threads moving.
The YZF project is awaiting carb parts so I can try firing it up.  I decided to finish cutting on my KZ frame.
« Reply #253 on: Mar 22, 2017, 23:05:54 »
Next I need to finish cleaning up the swingarm and get a coat of paint on it.  I still need to properly mock up the rear wheel.  I"m considering a final third frame brace in the lower triangle.  It will be functional but it's mostly because I think it will look good too.
« Reply #254 on: Mar 30, 2017, 19:13:33 »
I took a que off of Beachcomber and sourced a set of empty cases at a heck of a deal shipped.  I also have a set of jugs and heads coming.  Having a mock up motor made a ton of sense to me.  I needed both of my full motors on the bench to finish mix/matching to get the one I'll run.  This way maybe getting the engine and chassis ready won't stop me from figuring out rear set linkage, exhaust, etc..
« Last Edit: Mar 30, 2017, 19:15:35 by canyoncarver »
Offline clem
  • static fluff
« Reply #255 on: Mar 30, 2017, 19:56:37 »
Ahh, a project may always be a project and you'll always have many. Luckily you have that gas ang go bike.
Sent from my SAMSUNG-SM-G920A using DO THE TON mobile app
Offline beachcomber
  • TJ - Beachcomber
« Reply #256 on: Mar 31, 2017, 11:34:39 »
CC,
that's a hangover from my Drag Racing days with V8 s !!
Rather than throw away grenaded engines I kept them less innards for set ups and "whatifs".
I'm now going a stage further and obtained a non V5 [non - titled ] frame so I can try out / duplicate any set ups on the bench first without worrying about scratching paint / getting a hernia !!
« Reply #257 on: Apr 04, 2017, 18:09:28 »
Ahh, a project may always be a project and you'll always have many. Luckily you have that gas and go bike.
Truth.
Offline beachcomber
  • TJ - Beachcomber
« Reply #258 on: Apr 15, 2017, 07:46:17 »
CC - alternative forks - any ideas ?
« Reply #259 on: Apr 15, 2017, 21:40:39 »
I picked up a KZ1000 rolling chassis a bit ago and I'm using the forks and mag wheels from it.  Same diameter, I'm going to use the 750 trees and the 1000 forks are a bit of an upgrade, dual disc.  Other than that, my thoughts head towards a nice USD fork off something much newer.   What were you thinking BC?
