Author Topic: KZ 750 Twin - Two point zero  (Read 64721 times)
Online Brodie
  • Gold Coast, Queensland
Re: KZ 750 Twin - Two point zero
« Reply #250 on: Mar 12, 2017, 06:25:21 »
The c5 ignition for the Virago is driven off the cam, I wonder if the KZ could have the kit adapted.
Also there is a fair bit of discussion in using a VOES to control the timing maps with these. They are a nice bit of kit indeed
Offline beachcomber
  • TJ - Beachcomber
« Reply #251 on: Mar 12, 2017, 10:52:47 »
As ever, thanx for the info guys - sorry to bust in CC.
Offline canyoncarver
  • 'hacking is learning'
« Reply #252 on: Mar 22, 2017, 23:01:29 »
Never a problem BC, glad to have both threads moving.
The YZF project is awaiting carb parts so I can try firing it up.  I decided to finish cutting on my KZ frame.
« Reply #253 on: Mar 22, 2017, 23:05:54 »
Next I need to finish cleaning up the swingarm and get a coat of paint on it.  I still need to properly mock up the rear wheel.  I"m considering a final third frame brace in the lower triangle.  It will be functional but it's mostly because I think it will look good too.
« Reply #254 on: Mar 30, 2017, 19:13:33 »
I took a que off of Beachcomber and sourced a set of empty cases at a heck of a deal shipped.  I also have a set of jugs and heads coming.  Having a mock up motor made a ton of sense to me.  I needed both of my full motors on the bench to finish mix/matching to get the one I'll run.  This way maybe getting the engine and chassis ready won't stop me from figuring out rear set linkage, exhaust, etc..
« Last Edit: Mar 30, 2017, 19:15:35 by canyoncarver »
Offline clem
  • static fluff
« Reply #255 on: Mar 30, 2017, 19:56:37 »
Ahh, a project may always be a project and you'll always have many. Luckily you have that gas ang go bike.
"After every war there are soldiers who refuse to surrender. To this day there are still thousands who cling to their 30+ year old motorcycles, thinking that the war is still on, refusing to concede that the four-strokes have won"
1972 DS7 http://www.dotheton.com/forum/index.php?topic=45886.msg505995#msg505995
1983 CB550sc bobber http://www.dotheton.com/forum/index.php?topic=30599.30
Offline beachcomber
  • TJ - Beachcomber
« Reply #256 on: Mar 31, 2017, 11:34:39 »
CC,
that's a hangover from my Drag Racing days with V8 s !!
Rather than throw away grenaded engines I kept them less innards for set ups and "whatifs".
I'm now going a stage further and obtained a non V5 [non - titled ] frame so I can try out / duplicate any set ups on the bench first without worrying about scratching paint / getting a hernia !!
« Reply #257 on: Apr 04, 2017, 18:09:28 »
Ahh, a project may always be a project and you'll always have many. Luckily you have that gas and go bike.
Truth.
Offline beachcomber
  • TJ - Beachcomber
« Reply #258 on: Apr 15, 2017, 07:46:17 »
CC - alternative forks - any ideas ?
« Reply #259 on: Apr 15, 2017, 21:40:39 »
I picked up a KZ1000 rolling chassis a bit ago and I'm using the forks and mag wheels from it.  Same diameter, I'm going to use the 750 trees and the 1000 forks are a bit of an upgrade, dual disc.  Other than that, my thoughts head towards a nice USD fork off something much newer.   What were you thinking BC?
