Author Topic: 1970 CL350 resto  (Read 11849 times)
Offline bmfenn
Re: 1970 CL350 resto
« Reply #30 on: Apr 26, 2016, 14:11:38 »
Epoxy is a beautiful thing. My 360 is about 75% epoxy
It absolutely is. I have a lawn spreader, which got the leftover  epoxy from the headlight bucket. I swear there's more epoxy than original plastic in that old Scott's spreader.
Sent from my SM-G900V using Tapatalk
Offline bmfenn
« Reply #31 on: May 21, 2016, 10:26:17 »
Finally got the carbs back together last night. Been super busy with stuff around the house. Hopefully I can get this back running before I get sidetracked on other projects.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #32 on: May 21, 2016, 12:30:45 »
Carbs look great. How'd ya clean em?
Offline bmfenn
« Reply #33 on: May 21, 2016, 13:07:09 »
A co-worker of mine was a mechanic at a Yamaha dealer in a former life, and still does small engine repair on the side. After hurricane Sandy, he had so much work rebuilding lawnmowers, snowblowers, jetski's, etc that he invested in a good ultrasonic cleaner just to save time cleaning parts.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #34 on: May 21, 2016, 14:32:02 »
A-ha! Nice. I have made makeshift ultrasonic cleaners (with a handheld sander) before. They always work pretty well but there's no replacement for the real deal!
Offline bmfenn
« Reply #35 on: Jun 03, 2016, 11:13:14 »
No pictures of them finished, but I cleaned the rust off the air boxes,  primed and spraypainted them flat black.
Installed new throttle cable, and put the carbs back on, hooked everything up, just to realize the battery had gone dead. Battery is on the charger now.
Offline bmfenn
« Reply #36 on: Aug 17, 2016, 16:10:08 »
After rebuilding the carbs and replacing the paper in the filters with uni foam, I haven't been able to get it to run right. It would idle, but it would die with any throttle. Tore down the carbs again last night to realize that I didn't replace the rubber plugs under the idle jet. And of course I have no idea what happened to them. Look like I'll be ordering a set.
Back on the table
Foam air filters:
Offline 3DogNate
  • "You Meet the Nicest People on a Honda"
« Reply #37 on: Aug 22, 2016, 16:34:04 »
Boo.. I have little delays like that. Keep at it.
Offline bmfenn
« Reply #38 on: Aug 29, 2016, 16:38:38 »
While waiting for the passage plugs to arrive, I adjusted the valves, set the timing chain tension, and set the ignition timing. Rubber plugs came in, put the carbs back together, and last night she started up and ran great! Took for a quick ride around the neighborhood.
Offline bmfenn
« Reply #39 on: Aug 29, 2016, 16:40:43 »
Brought her out of the garage and gave her a quick bath.
