Author Topic: 1970 CL350 resto  (Read 10869 times)
Offline bmfenn
Re: 1970 CL350 resto
« Reply #60 on: Feb 28, 2018, 12:08:02 »
Been a super long time, but free time is something I haven't had much of. Frame is stripped. I could hear liquid inside the bottom frame tubes, so after hanging it upside down for a few weeks, I wound up drilling some 1/16 holes in the bottom tubes and some black mucky hurricane Sandy water drained out. After getting out as much as possible between gravity and a blowgun, I taped up as many holes as possible, and filled the inside of the frame with evapo rust, because any residual shouldn't harm the metal.  Any rust on the outside that the wire wheel couldn't get to has been getting hit with naval jelly.
Sent from my SM-G950U using Tapatalk
« Last Edit: Feb 28, 2018, 12:24:23 by bmfenn »
Online WhyNot
  • ~~~If it ain't raining, I'm riding~~{iii}?~~prost~
« Reply #61 on: Feb 28, 2018, 12:52:45 »
Neat little build, finally read thru the whole thread.
I like these little twin 350.
I'm currently working on one...................SL350, gonna chop the frame for a hard tail and see where it goes from there.
Know about time off or lack of, 12 hours M thru F and 10 on Sat, 8 on Sunday, been that way since Christmas.
Finally did get this past Sunday off, and got a picture of what I'm working on.
« Last Edit: Feb 28, 2018, 12:55:06 by WhyNot »
2015 Toyota Taco DD now
2006 Harley Davidson Heritage Softail
1975 Honda CB750K5 needs carb work
1974 Honda CB350F2 needs tins painted (being lazy)
1972 Honda CB175K2 roller no engine
1972 Honda CB/CL350 Engines need roller
1972 Honda SL350K2 Frame for above engine
1972 Honda CB100K2 needs kicker shaft
1990 Mitsubishi MM runs, but no power
1984 Dodge D50 Beater was DD since 1997
Offline bmfenn
« Reply #62 on: Jul 27, 2018, 22:48:36 »
Been slowly stripping priming and painting parts. Most recently I finally painted the frame. After wire Wheeling, sand blasting, etc again, I first went with a coat of rust reformer, followed by primer and then VHT chassis and roll bar epoxy paint in satin black.
Offline bmfenn
« Reply #63 on: Jul 27, 2018, 22:51:13 »
 pics of stripping and repainting the swingarm, again using VHT roll bar and chassis paint
Offline goldy
« Reply #64 on: Jul 29, 2018, 07:42:25 »
Keep it up! It's pleasantly refreshing to see someone restoring one of these rather than hacking it up. :)
1948 Norton ES2
1955 AJS 20B
1956 Triumph TRW
1968 Triumph T100 special
1969 Norton Commando
1975 XS650 Yamaha
Offline bmfenn
« Reply #65 on: Jul 29, 2018, 08:59:57 »
Thanks! It's not going to be a true resto, just because some parts are beyond restoration. But trying to keep it close and keep any mods functional and in the spirit of the original design.
Online WhyNot
« Reply #66 on: Jul 30, 2018, 07:46:44 »
Yeah, I've changed my mind of making a hard tail out of the SL frame.
I'm going to just try to get it as close as possible, with minimal mods, but keep it functionally safe to ride.
So keep up the build as I follow along.
