www.Moto-Madness.com
Author Topic: Darkness 78 CB750  (Read 12159 times)
Offline Tune-A-Fishİ
Re: Darkness 78 CB750
« Reply #70 on: Jun 11, 2017, 00:34:09 »
That rear brake is not gonna work, the pivot point is way too far back from the swing arm axle you need to raise it and pull the shocks so you can move the swing arm up and down to see what I'm talking about... also, good luck finding neutral.
Sweet bike tho
Offline J-Rod10
    • Slipstream Cycle Works
« Reply #71 on: Jun 11, 2017, 00:56:12 »
Run your linkage forward to the stock brake shaft. It'll allow you to run the stock light switch, and return spring, and you won't have your brake dragging everytime you hit a bump.
On the shift side, figure out how to run a straight rod. Kinked rod is going to flex.
Offline Hutch08
  • Old School - New School - Its all about the Fun
« Reply #72 on: Jun 15, 2017, 20:06:03 »
Foam..what a bitch lol. Comfy though. Now I have to clean this garage up bevcause it looks like snow in Phoenix. Ready to send to apholstery
Sent from my XT1585 using Tapatalk
Offline Hutch08
« Reply #73 on: Nov 14, 2017, 19:26:49 »
Decided to make my own switchgear after seeing the price tags online. Baught an aluminum block and micro switches and this is what they turned out as. I want to keep the handles clean and classy so I used the clutch and brake lever mounts.
Offline Bootsey
« Reply #74 on: Nov 18, 2017, 22:03:04 »
Nice work on the switches - got anymore info/pics on how they were made & mounted?
Offline Tylerg123
« Reply #75 on: Nov 19, 2017, 09:29:19 »
Gonna follow this build
Sent from my SM-G955U using DO THE TON mobile app
Offline Hutch08
« Reply #76 on: Nov 19, 2017, 23:09:02 »
So I found "the" set of what I wanted to buy from extremecreations.com but a $350 price tag was not feasible. Baught an aluminum block from Amazon with 6ea $7 micro switches and milled them out on a friend's machine.Made a template out of wood with the holes drilled and copied it once it fit correct. No pics on the process of it, didn't think of it at the time
Offline cb250nproject
  • If you can make it better do so
« Reply #77 on: Nov 20, 2017, 05:46:49 »
Looks crazy
first cafe build was an incomplete learning experience, more of a test run for the real thing FRANKENHONDA II
Offline Coopacoopacoopa
« Reply #78 on: Nov 20, 2017, 15:31:07 »
Great work on that switch block assembly. What micro switches did you use?   8)
Offline Hutch08
« Reply #79 on: Jan 04, 2018, 16:17:42 »
Received the new 4-2 exhaust from cycle x and it is awesome. Next to make the left side hangar. Carbs are all torn apart and cleaned, just polishing the top hats and float bowls till I can get the rebuild kits
