Author Topic: Project peer pressure ADV danger bike!  (Read 48781 times)
Offline Kanticoy
  • Mad Science!
« on: Mar 18, 2016, 12:48:28 »
Thanks in no small part to peer pressure from Mr. E and Deviant along with the Indy crew I started getting an inch and the only cure was more....enduro!
As circumstances would have it the story starts with my buddy Jared going down to Batteries Plus for a battery for his bike one day and the employee at the counter asked the question with only one answer. "So you like old bikes? I have one sitting at my house you can have for $100...interested?"  He answered yes. I knew about the bike as it sat idly in storage and through a little bit of horse trading I happened to have a set of Avon Roadriders he needed, a trade was sparked, and I opened the dark storage building and brought this home. It's a 1982 Suzuki DR500.
In all of its 80s broke back styling I was starting to see beneath the surface. The goal here was to have a capable off-road motorcycle that could easily ride on the street, and carry a stash of camping gear for the adventures I was conjuring in my head. So I leaned it against the shop and opened a beer, and began to design the bike in the normal fashion in my head.
I knew that the suspension was heavy and outdated, I knew the tank wasn't good for a long trip, and I knew that the motor was locked up. First things first I tore down the top end of the engine and thankfully the piston had seized with water at the very top of the bore so I was able to get it free and send it off for a one size over bore. I then sent the head out to Joe at DWMS Racing to have the valve seats and faces recut (turned out to be a blessing as he found a bent valve!).
While the motor was down, I put in a Barnett clutch and through a little gamble I discovered that an early DR650 stator and CDI would bolt into these cases. This is preferred because the original bike was a simple battery-less magneto with a lighting coil at 6v so I wanted to upgrade to 12v with a battery to allow auxiliary lighting and a 12vdc power outlet for gps and phone charging.
Old magneto:
New side cover with stator:
Barnett clutch and heavy duty clutch springs:
Motor cleaned up and 463lbs of dirt and gunk removed.
It was now time to start focusing on the chassis and suspension. The swingarm was very narrow on the original bike so I had to find something that would fit which turned out to be a headache. I discovered that a 2001 TTR250 swinger would fit if I made new mounts so I bought a used one off of eBay and rebuilt the linkage bearings and then added on custom pivot mounts to the frame after surgically removing the factory versions. I turned down a couple of pivot point bushings on the lathe and welded them in:
After finding an XR600 shock that would both for the swingarm and the frame (attached reservoir shocks wouldn't fit into the skinny frame) I finalized all of the mounts:
I then sourced a set of RMZ450 forks which are a common upgrade on DR650s and made a new steering stem and grafted them onto the frame:
And since that tank drove me nuts with the way it looked I sourced a 94 DR650 tank and fabricated new mounts on the frame to bolt it right up.
And then fabricated a rear master cylinder bracket:
Which gets us to where she now sits:
On the way is a new seat, fender, etc. next up is getting the motor back together when the head comes back so I can mock up the exhaust and air filter system and start finalizing the rear of the frame for pannier mounts and a rack. I'm hoping for a completion date of the Spring Thaw, but only time will tell! I'll try to keep you updated as I progress!
Peer pressure is a biotch!
« Last Edit: Mar 22, 2016, 00:59:21 by Kanticoy »
I get not knowing, but I can't for the life of me understand not trying. It's only metal it can be fixed. Man up and risk a mistake in exchange for a lesson.
Offline Sonreir
  • Moderator
  • Oregon
Re: Project peer pressure ADV danger bike!
« Reply #1 on: Mar 18, 2016, 13:06:46 »
I'm in.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline DohcBikes
  • Fuck You.
« Reply #2 on: Mar 18, 2016, 13:09:48 »
Consider a DRZ400 carb.
burning bridges sometimes light the most productive paths
Offline Kanticoy
  • Mad Science!
« Reply #3 on: Mar 18, 2016, 13:11:22 »
Considering this one was missing the carburetor when I got it (which could explain the waterlogged cylinder) I am on the lookout for a carburetor. That could be a very viable option.
Offline canyoncarver
  • 'hacking is learning'
« Reply #4 on: Mar 18, 2016, 13:17:19 »
You'll put your eye out....  glad you back at it online buddy.
73' The Commando
YZF750/1000R The Fly
KZ 750 Twin
ZRX 1100
KZ400 The Rabbit
KLR650, 69' Norton P11 Ranger, a 65' Atlas, a 60' BSA scrambler, 93" shovelhead chop, an 86' FXR, and an F9 Bighorn
more YZF750R's, more KZ's, a Zephyr750...and the ever unfinished 75' CB550 cafe.
Offline cxman
« Reply #5 on: Mar 18, 2016, 13:24:10 »
to small
go hsr42 mikuni pumper
1978 CX650 Super Deluxe
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1974 kawasaki 350 bighorn
1983 GL1100 aspy full dress
1983 GL1100 Nekid
and a bunch of others
Offline Kanticoy
  • Mad Science!
« Reply #6 on: Mar 18, 2016, 13:27:17 »
It was because of this:
Offline DohcBikes
  • Fuck You.
« Reply #7 on: Mar 18, 2016, 13:28:31 »
It's good for 40rwhp on the drz400 and makes the old 4 valve big bores very responsive compared to stock. Your engine is rated at 36bhp with the stock carb. Stock drz jetting would be very close to what you'll need.
Question: Your post says you went one size over on the bore, but your piston reads 'std'. Did I miss something?
« Reply #8 on: Mar 18, 2016, 13:28:51 »
;)  I'm thinking you'll need the hot stuff to finish this build.
73' The Commando
KZ 750 Twin
ZRX 1100
KZ400 The Rabbit
Offline Kanticoy
  • Mad Science!
« Reply #9 on: Mar 18, 2016, 13:29:38 »
to small
There isn't a whole lot of info out there on people who have modified these guys. Basically the 90-96 non electric leg DR650s are essentially the same block and of course this one has a 500cc +/- jug on it now, so it's really up in the air. It'll be a true dual sport with some road and some dirt, so I'm still trying to figure out what I need there, so any suggestions welcome. A tame carb is preferable to an "off/on" carburetor.
