Author Topic: Ugly Goose - Moto Guzzi 850T cafe  (Read 55515 times)
Offline Rusnak_322
    • STUNT BIKE
Re: Ugly Goose - Moto Guzzi 850T cafe
« Reply #140 on: Aug 29, 2016, 18:39:00 »
Any labels on the pins? It looks like it could be the voltage regulator.
Same symbols as this
Here is my reg/rec
The wiring is/was a mess. I am almost done. I got the rear light and rear brake switch done and the rest I understand. It is just that on resistor, it must be fore the headlight. All I have left to hook up is the headlight and the front hyd brake switch. I broke the wires on the other one and bought one with a brembo thread.
I have brembo master and calipers but the junction block has Nissan threads.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #141 on: Aug 29, 2016, 18:42:32 »
If it's the same symbol as the black box? In that case, it's probably just a relay for the solenoid.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline Rusnak_322
    • STUNT BIKE
« Reply #142 on: Aug 29, 2016, 18:58:17 »
One last question (for now).
I have a mini switch that I want to use for the start button.
With that white resistor or relay, can I use the small switch with thin wire safely? Or will I melt it?
The switch now uses a pretty heavy wire compared to the new switch.
See above. The thin wire is like 18 ga. The heavy black wire is to the existing switch. It goes to the Y on the white relay
Btw
Here is my wiring sketch
Offline Sonreir
  • Moderator
  • Oregon
« Reply #143 on: Aug 29, 2016, 18:59:19 »
You should be OK, but I'd test it just to be sure. You should be able to activate the relay by connecting directly to a battery. Use a multimeter to measure the current. Anything under 3A should be fine for 18 gauge.
Offline Rusnak_322
    • STUNT BIKE
« Reply #144 on: Aug 29, 2016, 19:33:39 »
Thanks!
Offline Perter
« Reply #145 on: Aug 30, 2016, 06:06:50 »
Looks nice with the rear sets, I see there is plenty of room with the exhaust you have chosen. I have Lafranconi Competizione with a LM1000 middle section and there's no way I could run the linkage like you do. Really inspiring to follow this Guzzi!
Offline Harsh
« Reply #146 on: Aug 30, 2016, 08:18:40 »
Rusnak...where did you find that tail light?
2014 Triumph Tiger
2007 Triumph Daytona 675 - Track Bike
1974 Honda CB750 Cafe
1972 (x2) Honda CB350
Offline Rusnak_322
    • STUNT BIKE
« Reply #147 on: Aug 30, 2016, 09:26:27 »
Amazon. $18 with free prime shipping. I will try to find a link to it.
It was cheap enough to take a risk that it wouldn't fit.
Offline Rusnak_322
    • STUNT BIKE
« Reply #148 on: Aug 30, 2016, 09:34:18 »
I mounted the light over the weekend
Used some glue and rivets
I put an crap load of tape on the drill bit to limit the depth as I am someone who would drill right thur the seat and poke out the top side.
I ground the bracket to give it some teeth for the glue to stick to.
I regret not thinking ahead and painting the raw steel bracket before I attached it.
« Last Edit: Aug 30, 2016, 09:37:59 by Rusnak_322 »
