Author Topic: Ugly Goose - Moto Guzzi 850T cafe  (Read 54838 times)
Offline Rusnak_322
    • STUNT BIKE
Re: Ugly Goose - Moto Guzzi 850T cafe
« Reply #170 on: Sep 20, 2016, 16:31:24 »
I made this at lunch trying to figure it out
Offline Sonreir
  • Moderator
  • Oregon
« Reply #171 on: Sep 20, 2016, 16:39:24 »
On the drum, the shaft I've indicated in the pic should have some adjustment in it.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline Rusnak_322
    • STUNT BIKE
« Reply #172 on: Sep 20, 2016, 21:59:10 »
Not much adjustment. Think I should try to lengthen it?
I think that it is where it was when I got the bike.
You can see the marks I made
Offline Rusnak_322
    • STUNT BIKE
« Reply #173 on: Sep 20, 2016, 22:00:45 »
These should do the trick:
http://www.ebay.com/itm/331081950192
I got the one in you link. A little larger then I was expecting, but it works! Thanks
I arced the positive side when my wrench hit it while adjusting the shift linkage
Offline Petrus Rocks
« Reply #174 on: Sep 21, 2016, 22:01:15 »
If you remove one side of the linkage on the brake drum, then apply both brakes, you can check the linkage rod length compared to where the brake shoes stop.
What is probably happening is one shoe hits before the other and you only get 1/2 the stopping power.  My bet is you will shorten the linkage rod.
If you're interested , you can re-arc the brake shoes so they contact fully with the drum.  You spray glue sandpaper to the inside of the brake hub-220 grit.
Lightly apply the brakes  as you turn them inside the hub.  Remove and you will see the high spots.  Keep turning and applying until you have full contact.  Vacuum up the dust with a good vacuum, wear a mask.  Old brake shoes may contain asbestos.  If this scares you, there are brake and clutch companies that can do this process.
Offline Rusnak_322
    • STUNT BIKE
« Reply #175 on: Sep 22, 2016, 12:54:46 »
Should the linkage be adjusted so that there is no free play and no "preload" on the brakes?
Offline Rusnak_322
    • STUNT BIKE
« Reply #176 on: Sep 22, 2016, 13:01:15 »
I think one of my issues is that the old brake directly acted on the shaft. Now with my linkage, the stub on the brake lever is shorter then the stub on the shaft, so for any given travel, it is turning less degrees. Is that colorectal thinking?
I can  shorten the one, but not lengthen the other.
Offline Rusnak_322
    • STUNT BIKE
« Reply #177 on: Sep 22, 2016, 17:37:13 »
Man I want this helmet -
Offline Rusnak_322
    • STUNT BIKE
« Reply #178 on: Sep 22, 2016, 20:47:07 »
It lives!
I road it about 6 miles tonight.
Need a little tweaking still but I have Saturday for that and Sunday is the Distinguished Gentleman's Ride - Cleveland. I set that as my goal to get it road worthy.
I still cannot find a cool headlight  that I like and I will need shocks and a horn eventually.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #179 on: Sep 23, 2016, 10:38:07 »
I think a Lucas S700P would look good on this one.
