Author Topic: Ugly Goose - Moto Guzzi 850T cafe  (Read 54259 times)
Offline Bevelheadmhr
Re: Ugly Goose - Moto Guzzi 850T cafe
« Reply #60 on: Jun 28, 2016, 16:51:04 »
Don't know for sure, but it looks like its been blasted, maybe vapour blasted or maybe bead blasted (silicone beads give a finish that looks like that, and can also give a satin look by smoothing out the surface imperfections).
BTW, just made a video just for you...  :)
Offline Rusnak_322
    • STUNT BIKE
« Reply #61 on: Jun 29, 2016, 13:30:10 »
I appreciate your help, but I don’t think that the Rub N Buff will work for me. I want my whole motor to be uniformly colored, so that means that the cylinders and heads would need that treatment as well. I don’t see it holding up. it seems to be mostly carnauba wax, which cannot withstand high temps. I found threads on car detailing sites where people had issues with carnauba wax on their cars in places like Texas. The heat from sitting in the sun caused the wax to break down. The SDS on the manufactures site says that the boiling point is 212° to  375°. I am not sure the temps that the air cooled motor runs at, but I think that would be higher than that. You maybe ok with just the cases, but I don’t think that it will last in my application.
https://www.amaco.com/t/mixed-media/metallic-finishes/rub-n-buff
Offline Rusnak_322
    • STUNT BIKE
« Reply #62 on: Jun 30, 2016, 11:45:38 »
Here is what my motor looked like.
here I had started painting -
I tried to buff out the corrosion with a brass wire wheel on a dremel, it removed enough that I couldn't feel it anymore, but I could still see it.
Offline Perter
« Reply #63 on: Jun 30, 2016, 11:49:39 »
The open "box" on the gearbox collects water if you run with a custom battery plate.
I have a custom plate myself (rather a lattice) and mine is full everytime i wash (every second month  :o) or when it had been sitting out in the rain.
I would suggest you drill some drain holes in it before you paint unless you plan to never run in wet conditions or even make a custom lid to cover?
Very nice paint job btw, it looks perfect on pictures. Is it with a spraygun?
« Last Edit: Jun 30, 2016, 11:51:33 by Perter »
Offline Rusnak_322
    • STUNT BIKE
« Reply #64 on: Jun 30, 2016, 11:53:14 »
This is after painting -
I painted the starter motor a different color. it is Cast Aluminum, and it is a more noticeable difference than it looks in the picture.
I did that on my last bike, I don't care for a bike motor that looks like it has just been spray bombed.
I took care to tape off everything that is not the motor case. I pulled the valve cover bolts and gaskets, and taped off the other fasteners that I don't plan to replace. I only left the bolts holding the gearbox to the motor.
I plan to paint the alternator cover a slightly darker color. I am still on the hunt for an aluminum one that I can polish, but I gave up on the idea of polishing the valve covers after I took a long look at them and all the pitting and scratches. The paint did a good job hiding those flaws, but I would be too anal to let them go if I were polishing them. Maybe I will keep an eye out for some after I get her on the road and change them out later.
Offline Rusnak_322
    • STUNT BIKE
« Reply #65 on: Jun 30, 2016, 12:18:25 »
thanks,
I rattle caned it.
here is my makeshift spray booth. it usualy holds the garbage cans, it was pretty windy out so it was nice to have a place to spray.
« Reply #66 on: Jul 01, 2016, 22:08:17 »
The engine looks great, you've got me wishing I'd done the same with mine. It'll be interesting to know how it holds up in the future.
Offline Rusnak_322
    • STUNT BIKE
« Reply #67 on: Jul 05, 2016, 15:44:36 »
I spent the holiday detabing the frame, grinding them smooth and blasting the frame with my soda blaster.
The soda did a great job removing dirt and grease but most of the paint remained. There were places that the paint came off easily, a lot of fasteners came clean. The rest of the paint has a flat texture to it that should be a good base for paint.
I has wanted to prime it with the high build primer, but it started to rain.
Offline Rusnak_322
    • STUNT BIKE
« Reply #68 on: Jul 07, 2016, 17:52:05 »
anyone know where to find a pair of velocity stacks with screen for a Dellorto VHB 30mm carb?
 I like the longer ones, but I don't like the idea of paying $65 each for a pair of them.
I understand the issues with running these, I will have a plate blocking the crap being thrown off the rear wheel and this isn't a bike that will be ridden a lot or in the rain.
this is what I am looking for-
http://www.ebay.com/itm/like/131546760820?lpid=82&chn=ps&ul_noapp=true
also looking for some straighter intake manifolds, this is purely for looks.
« Reply #69 on: Jul 07, 2016, 19:52:14 »
I got mine from the official Dellorto site here in the uk
https://www.dellorto.co.uk/product-category/dellorto-motorcycle-carburettors-parts/trumpets-manifolds/trumpets/
Normally parts are a lot cheaper in the US, so maybe you could try looking at the official US Dellorto sites (assuming they have one).
