Author Topic: The Amalgam: honda past meets present, take 2! or 3?  (Read 41233 times)
Offline jag767
    • Kinesis Moto
Re: Fuel injected Cb450 build
« Reply #10 on: Jun 01, 2016, 18:24:20 »
So Honda was so much less than helpful with anything technical- You would have thought I was the first person to ask who I could speak with to turn their cb500x ecu system into a stand alone efi management system  :o :o
That being said, the guys at power commander were immensely helpful. I figured out the ignition issues, as well as how to tune it. There's still a handful of sensors I am going to have to going to have to trick the ecu as reading as ok, but one thing at a time.  I will need to buy a few of their products to make life a littler easier. Their autotune system will be a huge help for sure.
Looking more and more doable as I dig deeper  ;D
Offline jag767
    • Kinesis Moto
« Reply #11 on: Jun 02, 2016, 15:03:45 »
Nastiness!!
Offline jag767
    • Kinesis Moto
« Reply #12 on: Jun 04, 2016, 14:20:17 »
This torsion bar setup is funky man. Anyone know if once the bolt on the side is removed if you just tap out the bar? I've also read some people stating remove the valves first, others says after. Nothing like conflicting information.
Oh, and picked up a tank off ebay. Needs a little love but almost rust free.
« Last Edit: Jun 04, 2016, 14:22:13 by jag767 »
Offline xulf13
  • West of Tennessee
« Reply #13 on: Jun 06, 2016, 00:53:21 »
Subscribed!
Just tap the bar out once you remove the side bolts. There is not that much tension there. I've rebuilt the CB450 about 3 times, and it gets easier by the third time and I always learn something or an easier way to do things on these bikes.
Offline jag767
    • Kinesis Moto
« Reply #14 on: Jun 06, 2016, 04:20:33 »
Subscribed!
Perfect, you just became one of my best friends  ;D
Seriously though, any questions I have I won't hesitate to ask. When I look at this head, it's like the knowledge of engine work I have learn goes right out the window lol.
Offline xulf13
  • West of Tennessee
« Reply #15 on: Jun 06, 2016, 10:41:20 »
Some of the best improvements I did on my cylinder head was to send it out to get upgraded valve guides so that I could use modern valve seals. There is a guy on eBay from Oregon who performs the work for you if you send him your head, he will also do a 3 angle valve job and can resurface your cam if need be. I had all this done to mine since I already had invested too much on my motor to not do this upgrade. Flugtechnik and I have made some of the same mistakes and learned from them and one another. He's helped me out a lot off line. You got a bunch of good guys here that can help you out of you let them. This place is like a knowledge portal.
Offline jag767
    • Kinesis Moto
« Reply #16 on: Jun 06, 2016, 11:26:23 »
I was thinking about running the conversion kit with springs, big bore, new cams, and im on the fence about doing the dry clutch with high output oil pump, but im not sure yet.  I have to see how budget unfolds. Ive been talking with team hasen honda, and im really interested in the products they offer, particularly their pistons.
Offline xulf13
  • West of Tennessee
« Reply #17 on: Jun 06, 2016, 11:41:00 »
Very cool, but it can definitely get expensive quick! Ask me how I know :-)
I guess it depends on your budget up front and your bottom line. It helps to have an end goal in mind also. This way you don't do things twice and spend twice as much.
I used oversize Wiseco pistons on mine which also had increased the compression to 10:1
Offline jag767
    • Kinesis Moto
« Reply #18 on: Jun 06, 2016, 12:19:48 »
On my 350f i didnt go nuts and the money pit was still deep lol. Yeah i saw those pistons, im looking at 11.5 :1 compression. Gonna be fun to kick over!
« Last Edit: Jun 06, 2016, 12:39:39 by jag767 »
