www.Moto-Madness.com
Author Topic: XS750 to XS896 big bore  (Read 29941 times)
Offline XS750AU
Re: XS750 to XS896 big bore
« Reply #190 on: Jul 29, 2017, 06:12:24 »
I fitted 2 different fenders for a look today. The first is mounted high and is from a Yamaha IT200, the second is mounted low and is from an XS750.
My preference is the low mounted XS750. What do you think??
Front view with the XS750 fender. Happy with the new headlight and having the speedo out there. Might put a flyscreen on, but we will see.
Pat questioned what would happen when the rear suspension bottomed out. It pretty much hits the top and the front simultaneously, so I guess that's OK?
“Engineering is the art of being approximately right rather than exactly wrong.”
Yamaha XS750-2D
Yamaha XS896
Husaberg FE550
Yamaha TT250
Yamaha IT200N
Offline stroker crazy
  • crazy as a fox
« Reply #191 on: Jul 29, 2017, 06:32:24 »
My preference is the low mounted XS750…
Mine also.
Crazy
“Ride like the Wind” W.H.
Offline datadavid
« Reply #192 on: Jul 29, 2017, 07:10:48 »
If you had one with more of a beak it would look nuts!
Offline XS750AU
« Reply #193 on: Jul 30, 2017, 06:01:13 »
Engine is in, but all is not perfect. Broke the last compression ring when assembling. Only one person to blame http://www.dotheton.com/forum/Smileys/default/cry.gif
The engine was always going to come out, but now it needs some work. Other than the ring, it has all gone together well and I am happy with the header and oil cooler. With the oil cooler squish plate the oil cleaner housing are level with exhaust and engine mounts. Looks like I will be able to change the oil filter without demounting the header.
The looks like the exhaust will all go together well, the muffler will go back a little further so the end is level with the axel. Now need to cut the flanges off the header and fit and weld the ones that I have made.
Yamaha XS750-2D
Yamaha XS896
Husaberg FE550
Yamaha TT250
Yamaha IT200N
Offline Ryan Stecken
« Reply #194 on: Jul 30, 2017, 06:26:14 »
Beautiful!!!
Gesendet von meinem SM-A310F mit Tapatalk
  • crazy as a fox
« Reply #195 on: Jul 30, 2017, 06:31:50 »
The bee's knees!
Crazy
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #196 on: Jul 30, 2017, 07:00:16 »
Beautiful!!!
Shame about the ring though...
My Blog:
Offline Psycrow
« Reply #197 on: Jul 30, 2017, 07:17:52 »
Looking great!!
Psy
Sent from my SM-G903W using Tapatalk
Offline Luugo86
  • '73 CB350, '78 XS650 Cafe Killer
    • ToadStool Cycle Co.
« Reply #198 on: Jul 30, 2017, 14:01:59 »
Welds on that exhaust look great. Did you do them yourself?
Live to Die, Die to Live
Offline XS750AU
« Reply #199 on: Jul 30, 2017, 19:30:01 »
The header is off a Triumph 1050 and is yet to be modified to connect to the Yamaha head. The Triumph pitch is correct but the inlets are cast and an oval shape which cannot connect. I have made up some new header tubes for the interface, now just have to cut and shut. I do not TIG weld, but have a friend at work who is very capable. Might cost me a beer or two.  ;D
Yamaha XS750-2D
Yamaha XS896
Husaberg FE550
Yamaha TT250
Yamaha IT200N
