www.Moto-Madness.com
Author Topic: XS750 to XS896 big bore  (Read 43673 times)
Offline XS750AU
Re: XS750 to XS896 big bore
« Reply #200 on: Jul 31, 2017, 07:32:58 »
Quote
He was selling these as he had just got a set of Keihins to replace them!!!
BST36SS carbies arrived today - obvious why they were so cheap  :-\
They are well and truly worn out. I will strip them down and see how bad they are. Could end up needing slides, guides, needles, tubes and o rings. In other word bucks!! I am going to put them as a possibility rather than a certainty to being fitted. The MkII's that I have are in excellent condition.
Ryan - the sling shot feature on the BST36SS appears to have an extra fuel rail and vacuum circuit? Did you block them off, as your photos don't show the extra tubes?? Reports are that the Sling Shot feature will not function without the vacuum from the airbox. So it will not be working on my bike.
“Engineering is the art of being approximately right rather than exactly wrong.”
Yamaha XS750-2D
Yamaha XS896
Husaberg FE550
Yamaha TT250
Yamaha IT200N
Offline Ryan Stecken
« Reply #201 on: Jul 31, 2017, 08:26:55 »
Hey tim!
I'm running pods on mine (which are working perfectly, a little lean,need to big up the mains).
I left the air vents (black plastic fittings) open and put hoses on them....no problems with synchro or anything!
Slides should normally wear little but the needle normally 'ovals' out the needle seat...If you want I can look up where I ordered the orings.check if youre mixture screw tips are not stuck in their orifice!!
« Last Edit: Jul 31, 2017, 08:28:56 by Ryan Stecken »
Offline XS750AU
« Reply #202 on: Aug 06, 2017, 05:40:38 »
Oil cooler is now on, with hoses, which I will trim down later to neaten it up.
From the first photo you can see why the head flanges needed to be replaced. I purchased 90o bends to make up new interface flanges. Turns out that they needed to be 70o, which meant a number of cuts and tacks to get then back to 70o. All tacked together, but might get new 70o bends if I can to make it a neater job.
The "special" kick starter does clear the exhaust.
Yamaha XS750-2D
Yamaha XS896
Husaberg FE550
Yamaha TT250
Yamaha IT200N
« Reply #203 on: Aug 06, 2017, 08:05:41 »
bee knees man!
Offline XS750AU
« Reply #204 on: Aug 07, 2017, 22:48:29 »
Just got confirmation on the supply of a new set of rings to replace the broken compression ring. Very happy with the support offered by http://stores.ebay.com.au/cruzinimage-au320?_trksid=p2047675.l2563. If anyone is asking about big bore kits they are well worth contacting. The prices are much better than others on Ebay for exactly the same kits and their service is absolutely first class.
No "short cuts" this time, and I will use a ring compressor!  :-[
Yamaha XS750-2D
Yamaha XS896
Husaberg FE550
Yamaha TT250
Yamaha IT200N
Offline datadavid
« Reply #205 on: Aug 08, 2017, 03:14:37 »
I also use cruzinimage pistons, was very suspicious of both the seller and the noname pistons at first, but my machinist said they looked alright, and measured out very even.
Offline XS750AU
« Reply #206 on: Aug 10, 2017, 06:18:26 »
The trimmers found some time to have a go at my seat. They made up the patterns and then a validation cover before they used the embroided panels. We are using Napa leather which will be fine as long as I stay out of the mud and rain. Vinyl would be more durable but just does not have the feel of good Napa leather.
I am thinking that it might look a little better if the "back lump: was extended forward about 25mm to line up better with the frame and shock transition. Any thoughts??
Any other comments or suggestions??
The back guard is going to be trimmed back a bit more after she has the roadworthy and is registered! Can be painful in Australia!!!
Yamaha XS750-2D
Yamaha XS896
Husaberg FE550
Yamaha TT250
Yamaha IT200N
Online stroker crazy
  • crazy as a fox
« Reply #207 on: Aug 10, 2017, 08:39:37 »
Any thoughts??
As it is, it lines up with an extension of the swing-arm pivot to top shock mount line.
Crazy
“Ride like the Wind” W.H.
Offline JadusMotorcycleParts
    • Jadus Motorcycle Parts
« Reply #208 on: Aug 10, 2017, 18:21:46 »
Looking awesome man.  Love the oil cooler and the exhaust adaptation.  Nice.
Offline XS750AU
« Reply #209 on: Aug 12, 2017, 07:13:14 »
Seat should be finished next week, I wanted to try my other tank. I think it is either an "E" or "F" version tank and it looks much better in the photos than the flesh. Planning to paint the previous tank  silver, but not with the contrasting red or blue colour? Any thoughts??
Fitted the indicators. Happy with the rears but the front foul the frame on full lock, so I am going to have to change them tomorrow. They don't stand out, and blend in with the bike which is what I wanted.
I made up the bike lifter, as the bike does not have a centre stand. The lifter uses the centre stand pivot points. I was then able to get the rear caliper in and get the back wheel in the correct location.
There is possibly a problem getting the exhaust out past the brake pedal and foot peg. Foot pegs are coming from the US  now. I have organised some new 70o bends for the headers, but could not source annealed 304 stainless tube so I am not sure how well they will turn out. Exhaust will be finalised once I have the foot pegs, so I know all the constraints.
360mm shockers have also been ordered, it will be great to get some shocks on and get a better picture of the finished bike.
I have seen a few people in other posts asking about removing rush from chrome parts. I soak them is diesel and then wire brush by hand. They come up very well. I will see if the foot pegs out of the US (salt) need such work.
Yamaha XS750-2D
Yamaha XS896
Husaberg FE550
Yamaha TT250
Yamaha IT200N
