www.Moto-Madness.com
Author Topic: XS750 to XS896 big bore  (Read 44885 times)
Online datadavid
Re: XS750 to XS896 big bore
« Reply #210 on: Aug 12, 2017, 11:06:13 »
The 304 will anneal first time you ride it, wont be a problem😉
Offline XS750AU
« Reply #211 on: Aug 13, 2017, 07:06:25 »
Hey Ryan
What did you do for the choke on the Mikuni BST36's?
What diameter pods fit the BST36's?
Thanks for your help.
Tim
“Engineering is the art of being approximately right rather than exactly wrong.”
Yamaha XS750-2D
Yamaha XS896
Husaberg FE550
Yamaha TT250
Yamaha IT200N
Offline Ryan Stecken
« Reply #212 on: Aug 13, 2017, 07:16:27 »
Hey Ryan
Tim
I didnt do anything yet.My friend Der Nanno bought a bowden puller from a lawn mawer and installed it.
IRC mine are 60MM in diameter,just measure the longer side of the oval and the round filter will adapt.Just make sure to trim back the rubber boot on the inside or it may block the air opening for the membrane.
Gesendet von meinem SM-A310F mit Tapatalk
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #213 on: Aug 13, 2017, 08:21:12 »
Yup, one of those lawn-mower throttles did the trick perfectly. Or you get a left-side XV750/920/1000 switch cluster and swap out the bottom case to make it look like this:
Filter-inlet has to be 63mm and yes, you may end up trimming the rubber part of it a bit.
My Blog:
Offline XS750AU
« Reply #214 on: Aug 13, 2017, 08:43:49 »
Thanks for your help.  ;D
Yamaha XS750-2D
Yamaha XS896
Husaberg FE550
Yamaha TT250
Yamaha IT200N
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #215 on: Aug 13, 2017, 10:21:37 »
You could, of course, go all in and dump the Triumph carbs in favour of a set of VM36s, which is what I did. There's some snowmobiles that use VM36 carbs, so they aren't more expensive than CV carbs, but you have to solder a lot of throttle cables and splitters etc.
My Blog:
Offline XS750AU
« Reply #216 on: Aug 13, 2017, 19:24:47 »
Quote
Guess we will have to line you (without the anchor) and Ryan up one day and see which carbies give the better performance!  ;D
Yamaha XS750-2D
Yamaha XS896
Husaberg FE550
Yamaha TT250
Yamaha IT200N
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #217 on: Aug 14, 2017, 01:31:45 »
That's quite simple: The VM36s (I used to run Triumph carbs on my first XS triple sidecar), but the Triumph carbs are less hassle to install ;-)
My Blog:
Offline XS750AU
« Reply #218 on: Aug 14, 2017, 06:34:09 »
Seat is now finished, very happy with it. But as I have said before the Napa leather is vulnerable to staining when handling in the shed. So it is not on the bike while I am working on it.
Yamaha XS750-2D
Yamaha XS896
Husaberg FE550
Yamaha TT250
Yamaha IT200N
Offline stroker crazy
  • crazy as a fox
« Reply #219 on: Aug 14, 2017, 07:48:34 »
Classy!
Crazy
“Ride like the Wind” W.H.
