Author Topic: Post a pic of your motorcycle as it sits  (Read 103733 times)
Offline chicagobob
Re: Post a pic of your motorcycle as it sits
« Reply #930 on: Jul 11, 2018, 17:15:47 »
The leather Bonneville seat is from Journey Project, which I think is based in Thailand.  Took about 6 weeks to get it.  Fits great and is comfortable.  Comes with leather dressing. See https://www.facebook.com/pg/OmegaRacer/photos/?tab=album&album_id=772327669553501
The BMW seat is the one that comes on their RNineT Scrambler.
Offline Sav0r
    • ChrisLivengood.net
« Reply #931 on: Jul 11, 2018, 20:20:24 »
I need to bump the idle up quite a bit, but she fricken rips. The new carbs are epic.
Sav0r the adventure.
Visit www.chrislivengood.net to get more information on my RD350 dubbed Mia Wallace as well as my other projects and snafus.
Instagram
Offline Sderbyshire
  • Into Sailing, classic Triumph cars and motorbikes.
« Reply #932 on: Jul 15, 2018, 10:38:59 »
The CB390 posing in the garden.
Still missing some key engine parts but looking good !
Steve
Offline cbrianroll
« Reply #933 on: Jul 15, 2018, 15:35:41 »
Finally got the tank, need to add a backbone and tank supports.
Offline canyoncarver
  • 'hacking is learning'
« Reply #934 on: Jul 15, 2018, 23:23:51 »
Working on the YZF and the FXR today.
73' The Commando
YZF750/1000R The Fly
KZ 750 Twin
ZRX 1100
KZ400 The Rabbit
KLR650, 69' Norton P11 Ranger, a 65' Atlas, a 60' BSA scrambler, 93" shovelhead chop, an 86' FXR, and an F9 Bighorn
more YZF750R's, more KZ's, a Zephyr750...and the ever unfinished 75' CB550 cafe.
Offline WhyNot
  • ~~~If it ain't raining, I'm riding~~{iii}?~~prost~
« Reply #935 on: Jul 16, 2018, 09:45:23 »
Finally pulled this out in the daylight.
I don't suppose someone has any tricks on fixing that kick starter shaft without having to yank the motor again and doing a split?
2015 Toyota Taco DD now
2006 Harley Davidson Heritage Softail
1975 Honda CB750K5 needs carb work
1974 Honda CB350F2 needs tins painted (being lazy)
1972 Honda CB175K2 roller no engine
1972 Honda CB/CL350 Engines need roller
1972 Honda SL350K2 Frame for above engine
1972 Honda CB100K2 needs kicker shaft
1990 Mitsubishi MM runs, but no power
1984 Dodge D50 Beater was DD since 1997
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #936 on: Jul 16, 2018, 10:26:01 »
Sweet little scoot! Since the shaft is junk anyways, you could maybe drill it for a bolt? It would weaken that area with the splines but that thing probably takes no force to kick it over so it may last you a while until you have to fix it the "right" way.
'78 Honda z50 - http://www.dotheton.com/forum/index.php?topic=76059.0
Online irk miller
« Reply #937 on: Jul 16, 2018, 11:56:01 »
The gear on these is on the outside of the case.  I'm pretty sure you don't have to split the case to change the shaft.  Don't try to cobble together a fix.  The shaft is not hard to find- even $25 on Ebay.  You need the splines to handle the torque.  I've seen people weld the lever on, tho.  With XL175's guys weld a Kawasaki end onto the shaft, since the shafts have become unobtanium.
Offline WhyNot
« Reply #938 on: Jul 16, 2018, 12:20:55 »
I've had the cover off, the gear is inside the casing.
Too bad I can't just come from under, have to pull the head, jug and all to split it......was just trying to see if there were other ways.
Oh well, looks like an engine pull.
Thanks for the response fellows.
« Reply #939 on: Jul 18, 2018, 13:16:11 »
88 NX650
