Author Topic: Post a pic of your motorcycle as it sits  (Read 120430 times)
Online Rat_ranger
Re: Post a pic of your motorcycle as it sits
« Reply #990 on: Aug 10, 2018, 13:58:14 »
You gotta catch up.  I've had electronic jets for a little while on this one.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #991 on: Aug 10, 2018, 14:02:22 »
Nice!
What setup are you using?
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Online Rat_ranger
« Reply #992 on: Aug 10, 2018, 14:06:35 »
Microsquirt ECU running msextra code.  Using mostly GM sensors.  Temp sensor is gm but modified by thedubshop for aircooled VWs.  Spartan wideband, custom intank pump, respaced gsxr600 ITBs, chevy LS2 coils.  Getting the intank pump set up was the hardest part.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #993 on: Aug 10, 2018, 14:11:44 »
Right on. Did you do your own tuning?
Online Rat_ranger
« Reply #994 on: Aug 10, 2018, 14:30:31 »
Yeah, set it up using tunerstudio and copied the stock advance curve.  Got it close around the neighborhood and then went on longer rides using autotune.  Now it's pretty good.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #995 on: Aug 10, 2018, 14:54:56 »
Ignition system is part of the Microsquirt system?
And just running with a TPS and tach or are you measuring air flow with a MAP or MAF or something?
« Last Edit: Aug 10, 2018, 14:58:24 by Sonreir »
Online Rat_ranger
« Reply #996 on: Aug 10, 2018, 15:01:40 »
I'm running alpha N rught now, ao just TPS and rpm.  I do have a MAP sensor hooked up so that I can switch to ITB mode and use MAP at low throttle/cruise and alpha n when vacuum signal drops.  With the MS extra code the ECU is controlling the LS coils, they are "smart" coils.  It is all triggered by a 36-1 wheel that replaced the advance mechanism.
Offline Sav0r
    • ChrisLivengood.net
« Reply #997 on: Aug 10, 2018, 16:23:32 »
I know some of those words.
Sav0r the adventure.
Visit www.chrislivengood.net to get more information on my RD350 dubbed Mia Wallace as well as my other projects and snafus.
Instagram
Offline cxman
« Reply #998 on: Aug 10, 2018, 16:32:31 »
what is your total system draw including pump?
1978 CX650 Super Deluxe
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1974 kawasaki 350 bighorn
1983 GL1100 aspy full dress
1983 GL1100 Nekid
and a bunch of others
Online Rat_ranger
« Reply #999 on: Aug 10, 2018, 17:53:38 »
I honestly don't know.  I don't have anything that can measure the draw.  It does seem to have plenty of power with the 200w PMA set up.
