Author Topic: Post a pic of your motorcycle as it sits  (Read 120795 times)
Offline canyoncarver
  • 'hacking is learning'
Re: Post a pic of your motorcycle as it sits
« Reply #1160 on: Jun 11, 2019, 16:02:49 »
I need to finish painting the bodywork and get this thing down the strip.  Just picked up a small Bosch water pump, so now I can fit the lock up clutch and Banshee clutch cover.  After I get a few parts machined that is....
Wow.  Can we see more?
Offline CrabsAndCylinders
  • Careful With That Axe Eugene
« Reply #1161 on: Jun 12, 2019, 01:21:08 »
This is very cool! I can't wait until it hits the strip.
Lighter, Quicker, Faster.
ZX-14, 900F x 2, 1100F, R100, CBR600, SR500, GT500, RZ350, KZ1000 x 2, Moto Guzzi Lemans lll, CBX550, RD 350, 750 SOHC police special, RG250, TL1000R, GT750, KTM Super Duke 1290 R, Harris/Z-1, Norton 750 Commando, Green 77 KZ650
Offline teazer
« Reply #1162 on: Jun 12, 2019, 17:06:49 »
Thanks.
Starting at the front end, the caliper is an alloy Economy Cycles replica with aluminum pistons.  Disk is a drag race unit retained with Titanium bolts.
Forks are RD350, suitably shortened. Stem was pressed out and replaced with a modified aluminum GSXR stem
Motor is RD350 bottom end with RD400 transmission, Banshee clutch, TZ crank and TZ750 (700 type) top end with Blaster reed cages and 34mm carbs.  Ignition is Motoplat self generating.  clutch cover is modified R5 to take a TZ water pump.
Radiator is some small dirt bike - don't remember which - on custom mounts
Tank is 1 gallon aluminum hiding under a carbon fiber tank cover with integral side covers.  That I molded around a set of RD400 side covers and a narrowed RD400 US style tank.
Swingarm is longer than stock and takes the wheelie bar.  Shifting is by CO2 cylinder through pressure regulator and solenoid triggered off a button on the left bar.  Power to that solenoid and shift light come from a 4 cell RC radio graphene battery.
Tires are slicks, rims are aluminum,  Seat is also aluminum.
I got the pipes as rolled cones (unwelded) so I had to weld the cones and then work out the shapes, cut and welded them to fit in nice and tight.
Much of the rear frame and some of the top tubes were replaced with Chrome moly thin wall tube, but same basic shape as stock without some of the more complex curves.
Nothing mind boggling difficult so far.  If the chassis works, I'd like to build a long stroke motor ie a 400 or maybe with a 10mm banshee crank but ports become an issue and it's cheaper and easier to go straight to a CPI banshee and skip to 120 plus HP.
Offline teazer
« Reply #1163 on: Jun 12, 2019, 17:07:52 »
Tank:
Welding aluminum was fun, but the next one will look much better....
Offline pacomotorstuff
« Reply #1164 on: Jun 13, 2019, 11:10:33 »
OUTSTANDING, RICHARD!
Keep us posted.
Pat
Online Hurco550
« Reply #1165 on: Jun 15, 2019, 22:07:47 »
The "tw200" as of this afternoon.
"If you want safety and sanity don't mess around with choppers to begin with and don't come crying to me for recommending something that broke down the line. You're going to be the "builder" so use your own judgment and build to you own personal levels of safety and sanity." - Chopper Handbook
Offline Rat_ranger
« Reply #1166 on: Jun 16, 2019, 03:25:19 »
The 80 XS is starting to look different.  2" lowered forks, superbike bars, a K&S left switch, and no wiring.  Still have a ways to go, but it's progressing quickly
Offline dewjantim
  • duc in the park.....
« Reply #1167 on: Jun 16, 2019, 06:51:40 »
Ducati F1 race replica is moving along slowly. Received a title last week along with frame stamps so I can number and title my new frame. Wheels painted, bodywork painted, front end built, aluminium swing arm purchased, front discs acquired,brake adapters bought, put the four pot Brembos that I got years ago on the front end, and a lot of smaller items made or bought. Now is time for the real work to start......
If it hurts....... you ain't dead yet !!!!!!
Offline NoRiders
« Reply #1168 on: Jun 17, 2019, 05:22:32 »
Offline VintageMBike
« Reply #1169 on: Jun 22, 2019, 10:15:52 »
1 of 5
5 bikes
