Author Topic: 82 Honda CB900C chop/racer  (Read 11446 times)
Offline djmaynard
Re: 82 Honda CB900C chop/racer
« Reply #60 on: Aug 09, 2017, 09:26:37 »
A Timesert is basically a threaded sleeve that is used to repair stripped threads in, say, engine housings.  The kits aren't cheap but if you've got a stripped thread then there don't seem to be too many options to repair it other that a Timesert or Helicoil.  I'm new to all this but from what I'm told the Timesert does a more secure job.  I repaired my stripped thread with the engine in the frame - it's doable but a bit tricky to access, and you also have to be careful to avoid the scarf/metal shavings from falling dropping into the engine housing (I used a lot of heavy grease, and went very, very slowly).
Here's a link to the kit I needed to repair the stripped thread - https://www.amazon.com/Time-Sert-M8x1-25-thread-1812-TIME-SERT/dp/B01MSPN7NH
Not sure about the bolt itself that you'll need but if you can find the specs for it (length/width and thread pitch) I'd be happy to see if my guy has one.  Or if you can find out whether or not bolts from different years' engines can be interchanged then let me know.
I've ordered the o-ring twice now, the ones I've received however both seem a little large for the bolt.  Not sure if that's how they're supposed to fit - I ended up using two generic o-rings that fit more snug and will see if any oil leaks out.
Let me know if I can help =)
I found one and ordered the o-ring and while digging for a hole punch for something else I came across the bolt that fits it and tried one year later.... still doesn't fit. Dang
Offline djmaynard
« Reply #61 on: Aug 25, 2017, 22:48:35 »
When measuring hose size, do you figure inside or outside of the hose?
Offline djmaynard
« Reply #62 on: Aug 25, 2017, 22:50:38 »
Working on the pet cock after finally getting around to it and thought I'd get an additional fuel filter since the massive amount of crud/rust I found
Offline Tim
  • Administrator
    • DO THE TON
« Reply #63 on: Aug 25, 2017, 23:15:30 »
The ID of the hose (inner diameter) is the most critical when finding a match for the fitting on the bike, but the OD is sometimes also important depending on where the hose is going.  But for a given ID, the OD of a hose for a specific function (i.e. fuel) isn't going to vary much.
Is this for the fuel lines?
Offline djmaynard
« Reply #64 on: Aug 26, 2017, 00:12:29 »
Yes from pet cock to carbs.
Offline djmaynard
« Reply #65 on: Aug 26, 2017, 01:05:45 »
Was going to try and find original fuel line, but anyone have any suggestions for a line that they have used for high temps?
Offline Cookie
  • God help the child who grows out of everything
« Reply #66 on: Aug 26, 2017, 08:14:32 »
Can't go wrong with regular, 1/4" fuel hose from the local auto supply store.
If you're looking for something more stylish, there's always clear fuel line , in a variety of colours (I use blue).
https://fortnine.ca/en/moose-3ft-fuel-line
Just as an example
* Insert something witty here *
81 CB750C
84 Tempter - well, most of it...
Offline CrabsAndCylinders
« Reply #67 on: Aug 26, 2017, 14:35:53 »
I like the look of clear fuel lines but I have heard that they break down much faster than black ones.
Lighter, Quicker, Faster.
Offline Cookie
« Reply #68 on: Aug 26, 2017, 21:44:14 »
I'm sure they do, especially with ethanol fuels. But they look cool and really, with the amount of fiddling, futzing and dumping money into these things that we do, whats a couple extra bucks on fuel hose every 4 or 5 years? Realistically, I used it because it's what was lying around and I didn't have to buy it.
81 CB750C
Offline firebane
  • braaaaaaaaaaap
« Reply #69 on: Aug 27, 2017, 00:27:16 »
Honda fuel line is 5.5mm for the petcock generally and can still be purchased. Much tighter and better fit than 1/4
