Author Topic: FRANKENHONDA II the 1982 DOHC CB 750F2 Build  (Read 64185 times)
Offline cb250nproject
  • If you can make it better do so
Re: FRANKENHONDA II the 1982 DOHC CB 750F2 Build
« Reply #630 on: Feb 16, 2019, 05:19:37 »
So another update from Old Man Murphy’s shed
So from the first picture you can see where the front edge was marked up where it needed to be rounded off.
this was done with the router then finished off by hand
Next the hole for the bolt that tightens the grip around the fork needed to be drilled and have a thread tapped
It needs two slits cut, the hole in for the idiot lights then polish, polish, polish, polish
I’m actually thinking I need to go to a CNC engraver to get OMM or Old Man Murphy put on it now
first cafe build was an incomplete learning experience, more of a test run for the real thing FRANKENHONDA II
Offline stroker crazy
  • crazy as a fox
« Reply #631 on: Feb 16, 2019, 06:14:21 »
Appropriate.
Crazy
“Ride like the Wind” W.H.
Offline The Jimbonaut
    • Lost Apostle
« Reply #632 on: Feb 16, 2019, 11:49:26 »
« Reply #634 on: Feb 19, 2019, 06:33:05 »
So OMM put the final cuts in for the fork clamp
Then he counter sunk the bolt holes. He used a steel plate to ensure he didn’t go too far.
Now we just need to cut the slot for the idiot lights, engrave and polish it.
After it’s engraved I’m going to use the leftover gold powder coating and fill the engraving with it then try and bake it.
Hopefully it works
Offline dwysywd
« Reply #635 on: Feb 19, 2019, 08:38:20 »
Do you have those laser engraving places in AUS? We have places here in the US that take a laser and they can engrave anything from wood to cold rolled steel. It’s a pretty cool process.
Offline irk miller
« Reply #636 on: Feb 19, 2019, 10:06:46 »
Anyone with a vinyl cutter can etch aluminum pretty simply, and with at least equal accuracy as any type of engraving.
« Reply #637 on: Feb 20, 2019, 03:41:51 »
That looks crazy
