Author Topic: Yamaha rd350 Road Racer Liquid Cooled!!  (Read 51497 times)
Offline Hurco550
Re: Yamaha rd350 road racer
« Reply #60 on: Jul 17, 2016, 18:53:55 »
Have any of you guys used the banshee pistons in an r5 top end vs an rd350 top end? I can't imagine there would be an issue doing so, but I figured I'd ask
~ bradj
Offline davedogg
« Reply #61 on: Jul 17, 2016, 19:04:02 »
Pretty sure you cannot use banshee pistons on a R5. The R5 is piston port and doesn't have the windows that the reed valve RD and banshees have.
Offline Hurco550
« Reply #62 on: Jul 17, 2016, 20:13:37 »
Well dang. Thanks for the info though man
~ bradj
Offline Redbird
  • Dolor est Magister Optimus
« Reply #63 on: Jul 17, 2016, 20:13:45 »
That's my understanding as well.
When you are Dead, you don't know that you are Dead. It is difficult only for Others.
It is the same when you are Stupid.
Offline Hurco550
« Reply #64 on: Jul 17, 2016, 20:14:55 »
Maybe I should build an Rd top end after all then, but teazer has already been putting a bunch of time into r5 port maps for me though
~ bradj
Offline clem
  • static fluff
« Reply #65 on: Jul 17, 2016, 22:01:51 »
The Banshee pistons do work in the RD350 but they need to be modified.  Good quality R5 pistons may be hard to find. I think that Wossner may be the best bet.
Sent from my SAMSUNG-SM-G920A using DO THE TON mobile app
Offline Hurco550
« Reply #66 on: Jul 17, 2016, 22:17:53 »
I did read about filing of the tab on the intake side for the rd's,  I just assumed it would be the same for the r5,but it seems like that is not the case
~ bradj
Offline Hurco550
« Reply #67 on: Jul 18, 2016, 02:40:19 »
Wossner pistons are about $130 a pop. Seems steep to me, but maybe that's the going rate for a quality piston these days
~ bradj
Offline TranceMachineVienna
« Reply #68 on: Jul 18, 2016, 09:52:18 »
This was one of the reaons i didnt buy a R5 cuz the pistons are really hard to get in Europe...I used on both of my RD stages (Stock 250 setup and modified 350) the pistons (Pro-X pistons) of the watercooled LC 350 (250)...they worked fine on the 250 and the 350 setup.
I still got my RD 250 jugs and pistons in my shelf, so if youre planning to go for that, let me know (shipping might be expensive from austria).
I also thought about going for Wossners but I went for Pro-X in the end, a friend explained to me that going for A to B in the city is not right thing for them (forged steel needs more time to warm up and i think its bored the lower play).
« Last Edit: Jul 18, 2016, 09:58:34 by Ryan Stecken »
Offline Shoeman
    • My old RD tuning pages from the 90's
« Reply #69 on: Jul 18, 2016, 09:54:52 »
Is he porting a set for you or just drawing port diagrams?   Here's basic RD setup for street use:   Raise exh port 1mm, widen it 2mm.   Widen the intake 2mm and remove the lip at the cylinder on the port floor.  Make sure both cylinders match when you're done. Leave the transfers alone unless you have a right angle hand piece.  Match the case top to the cylinder base if you like.   Cut the center tab off banshee Pistons as you already know bolt it back together and let it rip.
I like cilp-ons, clubman's and superbike bars depending on the bike.  And rear-sets.
