Author Topic: 1977 BMW R100/7 Sarcoplasmic Cow Hellride  (Read 44885 times)
Offline Hurco550
Re: 1977 BMW R100/7 Sarcoplasmic Cow Hellride
« Reply #370 on: Dec 02, 2018, 17:14:07 »
I like that headlight much more better with the gauges over it
~ bradj
Offline irk miller
« Reply #371 on: Dec 02, 2018, 18:01:50 »
Big difference, isn't it?  I think it was the size and the bulbous shape out in space that made it look so out of place.  Once the fender goes back on, hopefully it makes even more sense.  A completed seat should balance all that out, too.
Offline JustinLonghorn
« Reply #372 on: Dec 02, 2018, 18:55:24 »
That delrin cup is a righteous idea.
And for what it's worth, I like the big headlight.
Into The Sunset, CB750 build
TT500 the Animal
Offline irk miller
« Reply #373 on: Dec 02, 2018, 19:09:29 »
A cap for my weed hole.  LOL.
Offline Luugo86
  • '73 CB350, '78 XS650 Cafe Killer
    • ToadStool Cycle Co.
« Reply #374 on: Dec 02, 2018, 20:17:05 »
 Irk... I'm really diggin the desert sled thing man.. I have been wanting to build one for a few years now.. I have a little XL100 that is on deck for that type of build maybe next winter.
   That being said.. I like the alignment of the rear fender, and I like that you molded the pan for the seat the way you did. So lotta hubbub about the Headlight... did you ever think of messing with two  5or6 inch LED buckets mounted side by side? That's right up the desert sled alley.
Live to Die, Die to Live
Offline irk miller
« Reply #375 on: Dec 10, 2018, 01:13:14 »
Next step is to carve a master for the seat cushion. I carved it from insulation foam. Coated the foam in Epsilon, then skimmed with Dynalite. Next, Iíll make a mold of this master...
Offline Maritime
« Reply #376 on: Dec 10, 2018, 09:03:15 »
Looks good and should be comfy with the right foam.
Offline irk miller
« Reply #377 on: Dec 10, 2018, 22:38:42 »
Mold is made. Iím a ceramicist, so I have tons of plaster and plaster is cheap. Itís easy to clean up and itís non-toxic. Plus, it sets in an hour or less so you can make a mold in under 4 hours. I didnít use a box, because I wanted to keep the mold lighter and to use less material. So I used a slump process which requires you to let the plaster set up until itís like yogurt. Then you squeegee it into a mound over the form until it hardens. The plaster will get sealed with some stuff called Super Seal then coated with a mold release.
Offline Kanticoy
  • Mad Science!
« Reply #378 on: Dec 11, 2018, 01:06:37 »
Subframe, side covers and fender go back to stock.  Maybe now I can paint it without fear of undoing...
I just wanted to remind you of the irony of this post
I get not knowing, but I can't for the life of me understand not trying. It's only metal it can be fixed. Man up and risk a mistake in exchange for a lesson.
Offline irk miller
« Reply #379 on: Dec 11, 2018, 01:21:13 »
Hahahahahahaha!
