Author Topic: 1974 CB360 Fallin' Ditch Hell Ride  (Read 59301 times)
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
Re: 1974 CB360 Fallin' Ditch Hell Ride
« Reply #20 on: Jul 14, 2016, 23:24:04 »
Yessir.  ;)
Glad you're bringing it back, I got a little sad when I read you tore that little guy apart. That bike is half the reason I now have an XL  ;D
Offline irk miller
« Reply #21 on: Jul 14, 2016, 23:29:16 »
Thanks.  That's awesome.  The rest of it (minus the motor) is here... http://www.dotheton.com/forum/index.php?topic=66202.0 The motor is going into a kart after I rebuild the top end.
Offline ridesolo
  • You only bear responsibility for your own actions
« Reply #22 on: Jul 14, 2016, 23:45:07 »
Likin' it.
“Fight on and fly on to the last drop of blood and the last drop of fuel, to the last beat of the heart.”
— Baron Manfred von Richthofen
Please check out:  http://www.VetTix.org
This is on a low simmer out in the shop:
'75 Honda CL378: http://www.dotheton.com/forum/index.php?topic=56547.0
This one is FINALLY done: (!)
'70 Rupp Roadster: http://www.dotheton.com/forum/index.php?topic=67459.0
Offline irk miller
« Reply #23 on: Jul 19, 2016, 16:50:36 »
I got the Suzuki rim laced up to the 360 hub. Now we're 18in and aluminum front and back, wrapped in 120/80-18 Shinko 705 tires. The hope is this setup will be good on sandy or deep gravel back country and swamp roads., which makes up the bulk of country roads around here.  As soon as the brake parts come in, I'll start the dual disc front end conversion. Also mulling rear disc...
Offline crazypj
« Reply #24 on: Jul 19, 2016, 23:27:03 »
That's looking pretty good
Best thing I ever overheard
Brian Morgan, 1982
Offline irk miller
« Reply #25 on: Jul 20, 2016, 16:31:53 »
The brake plan is duel disc up front and disc rear. I also want rid of the thousand pound, undrilled stock rotor up front. Through some searching, I discovered that the CB's disc rivet pattern is the same as an EX500 bolt pattern.  So, I separated the stock disc from its center...
Drilled out the holes and tapped them for 8mm X 1.25, so I can use the EX screws. Machined the centering tabs to accept the smaller EX center hole...
Bolted together...
Offline irk miller
« Reply #26 on: Jul 20, 2016, 23:21:06 »
No metal stock over 4" in house, so I cut the end off a 360 hub and converted it into a rear disc carrier...
Offline xulf13
  • West of Tennessee
« Reply #27 on: Jul 20, 2016, 23:36:57 »
Wow, well I guess I'm in. Nice work so far man.
Offline doc_rot
« Reply #29 on: Jul 21, 2016, 01:28:04 »
nice work on that rotor
