Author Topic: 1974 CB360 Fallin' Ditch Hell Ride  (Read 62737 times)
Offline redwillissuperman
  • Keep it simple- engine, wheels, bars
Re: 1974 CB360 Fallin' Ditch Hell Ride
« Reply #330 on: Jun 10, 2017, 10:08:54 »
XL fender is more fitting to the style that MX is too flimsy also so paint will hold up longer on the more rigid plastic. I wouldn't be afraid to put a decent depth of foam for the seat insert, your gonna want the comfort.
Sweet little multi
Should hold up to this....
Offline irk miller
« Reply #331 on: Jun 10, 2017, 10:11:58 »
Ha!  Better, because that will happen.
Offline Tune-A-Fishİ
« Reply #332 on: Jun 10, 2017, 10:19:46 »
Offline irk miller
« Reply #333 on: Jun 10, 2017, 13:08:26 »
Sweet little multi
Thanks, Tune.  The plan for the seat is something like the early KX/XR/CR seats.  If they'd fit this frame better, I'd just fit one of those.  So, should be plenty of pad. May see if I can find a cheap pad and use it for the foam.
I think I agree about the fender too.  I love the shape of the early XL fenders, front and back.
Offline irk miller
« Reply #334 on: Jun 11, 2017, 02:09:00 »
Got it all wired up and lit it on fire.  Amazingly, this GL Dyna works like a charm.  Needs some adjustment in the carbs and the seal behind the advancer leaks like a sieve.  Fortunately, I bought all the seals, so it just a matter of swap . I hope I can do it without loosening any bolts.
Offline Maritime
« Reply #335 on: Jun 11, 2017, 10:44:54 »
Nice!
Offline irk miller
« Reply #336 on: Jun 12, 2017, 14:55:24 »
Well, it ran on one cylinder because the Dyna rotor needed two opposing magnets instead of just the one it had.  I should've known, but it took me flipping the rotor to realize what was going in.  For some reason having two sensors at 90° is all I though it needed, but it's also 2:1 which requires the extra magnet.  So, I drill a hole opposite the other magnet and epoxied a tiny fridge magnet in.  Now, it actually runs like a 378cc bike should run.  A little rough at the low end, so I'll double check the advance and move on to the carb tuning.
Offline Hurco550
« Reply #337 on: Jun 12, 2017, 15:07:48 »
even with the low end running rough, is it still a noticeable difference from a stock 360 vs a 378?
"If you want safety and sanity don't mess around with choppers to begin with and don't come crying to me for recommending something that broke down the line. You're going to be the "builder" so use your own judgment and build to you own personal levels of safety and sanity." - Chopper Handbook
Offline irk miller
« Reply #338 on: Jun 12, 2017, 15:19:46 »
For sure.  PJ's carb mod does wonders for the stock motor, though.  This also has an XL250 44 tooth rear sprocket, as opposed to the stock 34 tooth CB's came with.
Offline Hurco550
« Reply #339 on: Jun 12, 2017, 15:22:49 »
dang 10 tooth jump in the rear! WHEEEEELLLIEEEE TIMEEEEEE
that's awesome man. Ridesolo is doing the 378 with pj carbs. Im looking forward to riding the little booger whenever he gets it done
