Author Topic: 1974 CB360 Fallin' Ditch Hell Ride  (Read 62863 times)
Offline canyoncarver
  • 'hacking is learning'
Re: 1974 CB360 Fallin' Ditch Hell Ride
« Reply #430 on: Nov 08, 2017, 01:32:58 »
Wild.  What does it sound like?
Offline irk miller
« Reply #431 on: Nov 08, 2017, 07:06:08 »
It sounds good, actually.  Admittedly, it doesn't sound as good as that other exhaust.  This one is more throaty where the other one was smoother and quieter.  I'll put that can on the DR, I think.
Offline irk miller
« Reply #432 on: Nov 10, 2017, 19:45:16 »
Couldn't get much more than bog at WOT.  Turns out these VMs had a 190 main jet installed in them.  Way too big.  Dropped down to a 130 and moved the needle up one clip (on ring below center).  It's seems very happy right now.  It's still pretty buzzy though, so I think the carbs are not quite synced.  This big ass sprocket is making it quite the quick shifter.  I'll have to decide how it wants to play and figure out if I need to go smaller.
Offline crazypj
« Reply #433 on: Nov 11, 2017, 16:22:40 »
I tried that on 380, it's LOUD (too loud for British police so I had to make it quieter  ;D )
Best thing I ever overheard
Brian Morgan, 1982
Offline irk miller
« Reply #434 on: Nov 12, 2017, 11:19:33 »
Haha, this is loud. Not illegal loud, but itís loud. Iím going to work on the baffling to see if I can get it toned down more.
I ran it through some paces in the hills where I grew up. With this sprocket setup, 1st gear is useless on street. Itís super short shifting. Top speed is 80-85mph.
 I think the jetting needs to drop to 120 or 125, if there is a 125. 130 is close, but not quite right. I raised the needle, but I think that was a mistake. Iíll move it back to the middle, run it and see if the clip needs to drop one above center.
Hereís a glamour shot from the weekend on my Grammaís property. An area in the piedmont of upstate, South Carolina nicknamed Dark Corners...
Offline trek97
« Reply #435 on: Nov 12, 2017, 17:47:37 »
Sharp AF bro.  Some little heat shields will make all the difference.  Mine are just thin stainless and average around 100 degrees w bike at operating temp.
Held on w a SS hose clamp and SS zip tie.
Im sure you already found your jeans were about to catch fire.   ;D
« Last Edit: Nov 12, 2017, 17:51:22 by trek97 »
Offline irk miller
« Reply #436 on: Nov 12, 2017, 22:51:56 »
Hahaha
Offline stroker crazy
  • crazy as a fox
« Reply #437 on: Nov 13, 2017, 00:08:00 »
ďRide like the WindĒ W.H.
Offline cxman
« Reply #438 on: Nov 13, 2017, 08:18:12 »
goes up in 2.5 increments
125 127.5 130 132.5 ect till you hit 200
in the video it still sounds a bit boggy or timing late
and if your needle is that high you may want to go a bigger jet needle or needle ?
what do you have and are they both the same
how is your idle to 1/4 mixture
what slide do you have both the same ?
1978 CX650 Super Deluxe
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1974 kawasaki 350 bighorn
1983 GL1100 aspy full dress
1983 GL1100 Nekid
and a bunch of others
Offline cxman
« Reply #439 on: Nov 13, 2017, 08:32:54 »
in a small carb like that you may even be in the right range to go to a bleed type jet needle (4 stroke type)
for better atomization and economy at same power levels
they dont make them in the size ranges i usually use but they might for your range
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1983 GL1100 Nekid
