Author Topic: 1974 CB360 Fallin' Ditch Hell Ride  (Read 62865 times)
Offline irk miller
Re: 1974 CB360 Fallin' Ditch Hell Ride
« Reply #450 on: Dec 19, 2017, 16:07:58 »
Here’s the situation:
Slides are 2.5 cutout
5F21 needle
O-8 Primary needle jet
130 main jet
30 slow jet
I bought a P-0 bleed style needle jet to replace the primary style.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #451 on: Dec 19, 2017, 16:09:34 »
What size bleed style did you end up with? In my (limited) experience, you usually have to go a lot bigger on the needle jet when you swap from primary to bleed. Often a full letter up, or more.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline irk miller
« Reply #452 on: Dec 19, 2017, 16:16:11 »
Went from O-8 to P-0.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #453 on: Dec 19, 2017, 16:17:59 »
Cool. I'm interested to see how it turns out. Been meaning to go to VMs on my 378 for a while.
Offline MiniatureNinja
« Reply #454 on: Jan 13, 2018, 00:49:17 »
this is a great build I have been following from the start, regarding the oil injection into the rocker box, does that just dump into the galley or does it intersect with the end of the camshaft where oil can move around the cam and into the galley
'75 Honda CB360 - thread
Offline irk miller
« Reply #455 on: Jan 13, 2018, 02:13:52 »
Thanks.  Hopefully, a little a both.  The hole lines up directly with the end of the cam shaft, but it's above the seam between the head and the cover.
« Reply #456 on: Jan 13, 2018, 12:31:00 »
Great, I've seen a lot of oil mods but yours is the most clearly photographed and seams simple enough! yours is the version I will attempt
« Last Edit: Jan 13, 2018, 12:49:41 by MiniatureNinja »
Offline irk miller
« Reply #457 on: Jan 13, 2018, 12:58:16 »
It took me a minute to dig it up, as I couldn't remember if it was the 3RM CB360 or Kanticoy's Gretta.  On Gretta, Kanticoy did it similarly, but he drilled the valve cover at all the journals and used a rail to feed the oil.  He may be using a pump and reservoir, but I can't remember.  I do know he's using an external oil cooler.
http://www.dotheton.com/forum/index.php?topic=10530.1270
Offline crazypj
« Reply #458 on: Jan 14, 2018, 01:13:01 »
Yep, I have full breakdown somewhere, found an electric pump that wouldn't 'kill' 360 generator but I don't remember if external reservoir was added as it would need drain back to sump.
 Over-engineered in my opinion but I believe zero chance of cam/rocker damage plus all the extra lines, distribution points, etc. looks damn cool  8)
« Last Edit: Jan 14, 2018, 01:15:33 by crazypj »
Best thing I ever overheard
Brian Morgan, 1982
« Reply #459 on: Jan 14, 2018, 01:22:19 »
I know that there are micro oil pumps out there for industrial or specialized applications, I would love to find one that wasn't much larger than the starter solenoid and do it that way
