Quantcast
Author Topic: 1974 CB360 Fallin' Ditch Hell Ride  (Read 64272 times)
Offline Brodie
  • Gold Coast, Queensland
Re: 1974 CB360 Fallin' Ditch Hell Ride
« Reply #60 on: Aug 06, 2016, 06:28:12 »
I need a cush drive, thinking of using a front hub as a rear. I will be very interested to see what you come up with.
Offline irk miller
« Reply #61 on: Aug 06, 2016, 18:05:46 »
Here's what we have so far...
4 bolt pattern for the disc and 5 bolt pattern for the cush. I'll cast 85A urethane with threaded inserts to fit the hub. Fortunately, the hubs are webbed to set up nicely...
And with an NSR disc...
The hub side is machined to fit over the center of the hub, the brake side center is machined for a 52mm X 17mm X 15mm bearing plus dust seal. Bearing and urethane on order, and hopefully will show up this week.
Offline Tune-A-Fishİ
« Reply #62 on: Aug 06, 2016, 18:07:42 »
NOOOOOW im understanding the direction  :o
Offline trek97
« Reply #63 on: Aug 06, 2016, 20:47:22 »
Im still not seeing it.  Youre gonna fit the 5 body drilled holes for bolts toooo where?
Offline irk miller
« Reply #64 on: Aug 06, 2016, 20:55:34 »
Do you know how a cush drive works?  Similar concept, just the brake side.
Offline trek97
« Reply #65 on: Aug 06, 2016, 20:55:53 »
OH OK now I get it.  Missed filling the cavity w the urethane part. 8)
Offline irk miller
« Reply #66 on: Aug 06, 2016, 21:03:07 »
;)  Just using the hub as a mold, since it's there.  I'll get the hardware together on the carrier, mix and pour the urethane and let it set.  It'll pop out and have the shape of the interior of the hub.  The hub is held tight by the axle, so it really just needs to be held from spinning.
Offline doc_rot
« Reply #67 on: Aug 06, 2016, 21:51:55 »
that carrier is sweet! seems like a prime opportunity for some cool pocketing.
Offline irk miller
« Reply #68 on: Aug 08, 2016, 17:32:29 »
Thanks, Doc. I agree.
Time for front caliper mounts while I wait for stuff to finish the rear. I ground away some of the CB750s fork lower and drilled/tapped through the stock mount. I'm running a bracket topside through that hole plus the fender brace hole. This is a functional mockup, as I want to be able to run it to test, but later mill it in alloy.  I cut and shaped the bracket in 1/4" steel plate, plus machined two 25mm spacers to offset the caliper, which will get welded in place...
Offline irk miller
« Reply #69 on: Aug 09, 2016, 12:02:28 »
Fresh and clean so far, with recall tensioner. Light spalling on the cam and rocker pads.  But it's wet up there, which is a good thing...
