Author Topic: A CB360 Build - Lil' Sebastian Rides Again  (Read 18264 times)
Offline Sonreir
  • Moderator
  • Oregon
Re: A CB360 Build - Lil' Sebastian Rides Again
« Reply #11 on: Jul 11, 2016, 21:12:33 »
Following along.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline Sderbyshire
  • Into Sailing, classic Triumph cars and motorbikes.
« Reply #12 on: Jul 12, 2016, 03:54:30 »
Even with the built in protection, lithium cells are not a good idea on CB/CJ250/360
Bike doesn't charge well enough and regulator isn't accurate enough to prevent battery damage
Indeed.
I initially 'upgraded' to the Kohler reg rec but it didn't control the voltage well enough, going above 15.
I've now replaced with one of Matt's Sparckmoto regrecs and it seems to be working well.
I've replaced all the bulbs with led, so the load when running is circa 4 amps, which shouldn't stress the ancient charging system too much.
Steve
« Last Edit: Jul 12, 2016, 03:56:18 by Sderbyshire »
Offline el barto
« Reply #13 on: Jul 12, 2016, 05:24:28 »
I used one similar to this on my CB750, but mine has 4 circuits instead of 3.  It's pretty compact.
http://www.ebay.com/itm/3-Way-Waterproof-Fuse-Block-Box-Holder-w-Black-Cap-Motorcycle-Boat-Atv-Car-Truck-/301994167394
Ahhh that's nice. Much tidier than the one I got. Good shout.
Nothing doing over the next couple of days as I wait for parts (annoying parts like connectors; wires - nothing exciting). Boring.
Question: when installing the exhaust headers and bolting everything up I was getting quite a lot of play, even though everything was done up tight and I THOUGHT I'd got the headers fitting snug against the ports. Took the headers off and the new crush gaskets didn't look like they'd been touched. Any suggestions?
« Last Edit: Jul 12, 2016, 06:10:20 by el barto »
Offline el barto
« Reply #15 on: Jul 12, 2016, 08:04:51 »
Do you have the half moon shims in there?  They go in-between collars and the flange at the end of the pipe.
http://www.ebay.ie/itm/Honda-NOS-CB350-CB400-1974-76-Exhaust-Pipe-Joint-Collar-18233-303-010-c4-/390551717423?hash=item5aeeb2462f:g:78kAAOxyaTxRL41M
I've got these in there:
Offline irk miller
« Reply #16 on: Jul 12, 2016, 08:08:32 »
I wonder if yours are the wrong size.  They can be as long as 40mm or so.
Offline el barto
« Reply #17 on: Jul 12, 2016, 08:17:39 »
Hmm interesting. These are what came with the bike, and I simply swapped them over from CB headers to CL headers. You reckon it's worth getting new/longer shims?
Offline Sonreir
  • Moderator
  • Oregon
« Reply #18 on: Jul 12, 2016, 10:20:10 »
The short ones are the ones you want. No difference between the CB and CL, but the CJ has different ones.
The longer set pictured above are the kind for the smallest SOHC fours.
Offline el barto
« Reply #19 on: Jul 12, 2016, 10:24:56 »
Aight thanks Matt. Any suggestions on getting a tighter fit? I was thinking that upon adjusting the flanges maybe I'd knocked the joints out of position causing them to be loose...
