Author Topic: A CB360 Build - Lil' Sebastian Rides Again  (Read 19522 times)
Offline el barto
Re: A CB360 Build - Lil' Sebastian Rides Again
« Reply #30 on: Jul 20, 2016, 16:48:36 »
Thanks Matt. Gave it a try but no joy.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #31 on: Jul 20, 2016, 16:54:30 »
And your black and black/red wires both have power?
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline el barto
« Reply #32 on: Jul 20, 2016, 16:59:11 »
Yeah. A swap back into the stock controls sees everything working as it should.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #33 on: Jul 20, 2016, 17:18:03 »
Sounds like it's time to break out the multimeter and check to make sure the wire colors are doing what you think they are doing.
Offline el barto
« Reply #34 on: Jul 20, 2016, 19:03:33 »
I've gone back to the old controls for now but I will probably definitely be hitting you up again. For the moment though, everything is wired up with the exception of the neutral light.
Offline el barto
« Reply #35 on: Jul 20, 2016, 19:11:41 »
Few bits today, mainly electrical with the kind help of Sonreir - finally most of the electrics are done.
Lil spray booth I cleverly knocked together (could also double as emergency underwear?):
Getting fuck all done while on dad duty:
Offline irk miller
« Reply #36 on: Jul 20, 2016, 19:44:25 »
Yeah, man.  Ain't that the shit.  The best is when you find random bolts in random holes all over the bike.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #37 on: Jul 20, 2016, 19:48:25 »
I had the cylinder jugs off my 360 for a few weeks while I was getting some head work done.
After putting almost everything back together, I dropped one of the cam gear screws down the chain valley and into the bottom end.
Angry didn't begin to describe how I felt.
Anyway... I pull everything apart to find the screw I dropped and it turned out it was a pretty wise decision. In the time I had things open, my daughter had decided that two bolts, two washers, a nut would also make a fine addition to the contents of the engine cases.
Offline johnu
« Reply #38 on: Jul 20, 2016, 20:21:36 »
It'll be a good memory though ;D
Offline el barto
« Reply #39 on: Jul 21, 2016, 05:17:38 »
 ;D ;D ;D
