Author Topic: Project "walrus" Yam XS 750  (Read 55508 times)
Offline TranceMachineVienna
Re: Project "walrus" Yam XS 750
« Reply #450 on: Jan 09, 2019, 06:18:08 »
Good advice thanks guys!
Do any of you guys know the oil amount of the deeper oil pan (no oil cooler)?
« Last Edit: Jan 09, 2019, 06:20:27 by TranceMachineVienna »
Offline datadavid
« Reply #451 on: Jan 09, 2019, 06:51:48 »
I have tried to research that, but found no actual answers. Mine takes 4,5l oil before it reaches the oil stick. More than my cars!
« Last Edit: Jan 09, 2019, 06:55:09 by datadavid »
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #452 on: Jan 09, 2019, 18:08:17 »
Bottom of the inspection glass, is somewhere around 3 to 3.5L. And you should fit an oil-cooler or drive faster.  ;)
(Just kidding, it makes a huge difference in Summer and both the coolers are and the adapter are easy enough to get overhere.)
My Blog:
Offline datadavid
« Reply #453 on: Jan 10, 2019, 00:33:38 »
Sounds like i should get a sidecover with a sightglass to save some oil then
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #454 on: Jan 10, 2019, 12:13:31 »
I'll know after the next oil-change definitely had filled up too much this time.
My Blog:
Offline datadavid
« Reply #455 on: Jan 10, 2019, 12:20:23 »
Wow. Now i had a satori here.. i had lower rear shocks last time i changed oil, so the engine was tilting slightly upwards - and the oil stick is in  front end of the sump. So my oil would have gathered in the back of the sump, meaning i  overfilled quite a lot. No harm done though, would only lube the gearbox a bit extra.
