Author Topic: Suzuki FA50 Moped - "The Bumblebee," or, my first two stroke  (Read 18615 times)
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
I started out today with spark, not great but definitely there. Cut the end off the plug wire and got a new bite with the cap and ended up with a nice fat blue spark. The exhaust was caked up with carbon and misc junk from being stored, so I ended up hacking off the tip of the muffler to clean it out. I'll run it like that temporarily until the welder is set up.
The carb was cleaned and reinstalled, even though it hardly needed it. The needle is set to the middle.
The petcock was a little sticky but a squirt of WD  and it freed right up. I've got fuel to the cylinder, after cranking it a few times the plug is wet, but it's not sounding like it wants to start. I kick it over, but it's not firing. Somewhere between then and now I lost spark, so one of the dang ignition switches must have shorted out. Another project for another day.
I was originally thinking the timing was off, but in order to change it I need to pull the flywheel, with a tool that I don't have. Could also be something stuck in the reed valve, or the crankshaft oil seal if it's real bad. Not sure where to look next.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
Got sick of looking at this thing on the bench so I decided to get into it. About 20 minutes later we had this:
Trans case clean, as expected. The kicker shaft is indeed bent about 1/8" out at the very end. I chucked it up in the drill press to get an eyeball on it.
Cylinder and piston all good. Rings moving freely. Inside of the case looks clean as a whistle.
When I pulled the carb for tear down, the bowl was empty. Since compression above the piston was 90psi, I'm leaning towards a leak in the crankcase. I'm thinking it's one of these few things causing the problem: the 2 crank seals, the reed valve sealing to the top of case, or where the carburetor bolts onto the intake.
Offline JustinLonghorn
Re: Suzuki FA50 Moped - "The Bumblebee," or, my first two stroke
« Reply #12 on: Sep 01, 2016, 10:41:02 »
In for the No-ped.
Into The Sunset, CB750 build
TT500 the Animal
Offline DesmoBro
  • Busted Nut
« Reply #13 on: Sep 01, 2016, 18:12:52 »
You gonna go full out crank up rebuild with a kit and bigg carb and pipe? ......PppppppPlease...........do more reasearch ! What if a motobecane race crank fits right in ? What then?
"I desire the things that will destroy me in the end"
« Reply #14 on: Sep 01, 2016, 18:53:28 »
What then indeed!
TT500 the Animal
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
Oh damn. Turbo scooter!!!
I'm trying to get to the crank seal over here, but this centrifugal clutch thingamjig is in my way. Manual says I need a clutch holder tool, but it's discontinued everywhere and I can't even find a good picture to make one. Any ideas?
Offline DesmoBro
  • Busted Nut
« Reply #16 on: Sep 02, 2016, 00:55:44 »
Search Moped Army repair section ****hint *****search all dates not just last month...but i think motion pro has one that could work
There may also be stuff in the moped wiki
There is also a tuning spreadsheet so you can see what kit pipe jet speed etc....others used & got
And if you search in the performance section youll see all sorts of tricks
« Last Edit: Sep 02, 2016, 01:07:16 by DesmoBro »
Offline stroker crazy
  • crazy as a fox
« Reply #17 on: Sep 02, 2016, 01:12:10 »
And if you search in the performance section you'll see all sorts of tricks
This may be gathering momentum!
Crazy
“Ride like the Wind” W.H.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #18 on: Sep 02, 2016, 02:10:48 »
I actually have read through there. The formatting on that forum makes it a pain in the ass to read though. I guess a popular mod on the FA50 is to shave the mating surface of the head, I think you can take about 1mm off to make the fins sit even with the cylinder. I'm not set up for it, all I have is a belt sander
Offline Nj732port
« Reply #19 on: Sep 02, 2016, 08:17:11 »
more has been done with less 8)
inspiration?
