Author Topic: First build ever  (Read 22091 times)
Offline onefromexile
Re: First build ever
« Reply #160 on: Apr 23, 2018, 19:37:32 »
Ok so after 3 hours of work was able to get parts on
And front end on
Had to pull triple off the cb750f frame I had
Because steering stem wasnít long enough on the cb450 k6 forks I got
I had to use both shims that came with kit  so I have a 1980 cb750 triple that has a different off set than the triple I planned on and I still have to buy a fork seal kit to put on the cl450 lowers that have the drum brake mounting and a 450 axel because itís a lil longer to make up for the distance
Oh and cut and grind down the handle bar mounts drill and tap holes to make a switch mounting plate
Was only able to install half of rearsets as the brake side kit came with no instructions and 2 dirrent peices neither which I can use with original parts
So I have to mod a 225$ bolt on bike specific kit???
Fun
« Reply #161 on: Apr 23, 2018, 19:38:37 »
Here he is beefy front
Offline crazypj
« Reply #162 on: Apr 23, 2018, 20:18:44 »
I got a little carried away making vacuum adapters so everyone waiting for carbs, parts and vac adapterswill have to wait yet another day. I thought I had 25 pairs (50 total) but turns out I have 41  ???
Not quite finished, still have to turn taper on them but this took me just about all day (until 4:30 when I had to pick up Jaxon from daycare)
Drilling the hole down middle is most time consuming part, because it's only 5/64" the swarf builds up in drill flutes and drill has to be removed from hole multiple times to clear it. I was using 1/16" drill but because they are shorter I had to drill from both ends so adapters took even longer to make
« Last Edit: Apr 23, 2018, 20:22:43 by crazypj »
Best thing I ever overheard
Brian Morgan, 1982
« Reply #163 on: Apr 23, 2018, 20:21:27 »
I got a little carried away making vacuum adapters so everyone waiting for carbs, parts and vac adapterswill have to wait yet another day. I thought I had 25 pairs (50 total) but turns out I have 41 (???)
Sweet one of those sets is mine
They look great
Did you ever find ur dremel??
« Reply #164 on: Apr 23, 2018, 20:28:20 »
They look great
About to measure mad numbers try to use the rake and trail calculator to figure my new numbers
With the k-7 triple itís off set 50mm so Ijust want to make sure Iím in good
If Iím a lil unstable I can put a damper it has mounts all ready
First build ever
« Reply #165 on: Apr 23, 2018, 20:53:13 »
Numbers look very similar to before
Very little change in handling I suspect
Plus I planned on raising back 1 inch with slightly longer rear shocks that will lower my trail a lil but still be in a good spot
« Last Edit: Apr 23, 2018, 21:00:58 by onefromexile »
Offline crazypj
« Reply #166 on: Apr 23, 2018, 21:02:00 »
Not yet but garage is getting a bit cleaner ;D
I need it to de-burr starter plug. So far, I know where it isn't   ::)
I don't think anyone realises just how much work goes into something as simple as a vacuum adapter,.
AS I mentioned, drilling hole is biggest PITA but I'm 'chasing' the threads by hand at present to make sure they screw all the way down, the lead in taper on die plus short thread length means the thread isn't 'full' for the full 6mm length.
Everyone is 'getting lucky' with this run, I bought wrong O-rings for float bowl drain screws so rather than 'waste' them I'm going to fit them on adapters (not sure they need it, I've been using 'bare thread into carb for years)
I should have adapters,   starter plug  in mail tomorrow afternoon, not going to taper all 41, just the 3 sets I need to mail out
 You almost always end up with more trail when you have less offset the only time you end up with less is if forks are much shorter than stock. Always amazed me how little the CCS classic racers actually knew anbout varying stuff, the general consensus was less trail made bike steer quicker but they almost entirely had more trail with less offset and 'raved' about how much better things were. I gave up trying to explain very quickly  :o
« Last Edit: Apr 23, 2018, 21:11:54 by crazypj »
Brian Morgan, 1982
Offline CrabsAndCylinders
« Reply #167 on: Apr 23, 2018, 21:12:29 »
What are these for, Crazy, syncing carbs?
Lighter, Quicker, Faster.
« Reply #168 on: Apr 23, 2018, 21:42:15 »
If you got my carbs mailed out
Already???
Starter plug and adapters shouldnít be too much postage
Coulda saved on ship
« Reply #169 on: Apr 23, 2018, 21:45:23 »
Already???
Yes for syncing
Necessary
Iím running mods on engine and had crazy do my carbs
So Iíll be fine tuning for a lil and break in
But well worth it
Will send pictures of carbs when I get in mail
Crazy did his thing
