Author Topic: GL500 Silverwing Scooped for $125  (Read 13581 times)
Offline Maritime
Re: GL500 Silverwing Scooped for $125
« Reply #50 on: Mar 02, 2017, 15:55:20 »
Mine looked like that, came out working fine with elbow grease an lots of cleaner
Offline KoŽstum
    • Motion Photos
« Reply #51 on: Mar 02, 2017, 19:07:31 »
Ah cool, the slide is a piston instead!  Well I hope the pistons are not in too rougher shape then  ;)
It was running before the teardown so I'm just going to clean them the best I can and skip a rebuild on the carbs if possible. If they need rebuilt later they're easy to remove and I'll do it then.
Los Gatos, CA
1978 Honda Twinstar cm185cc: The Black Pearl project
1982 Honda GL500 Silverwing Project
Motion Photos On Facebook
'86 Honda VT700, just bought on April 29 '17
Honda z50 (sold)
Honda CB125... the original... long gone :(
Honda cb360 (sold)
Honda cb400f (sold)
Honda cb450 (sold)
Honda cb500t (sold)
Honda cb550 (sold)
'75 Honda cb750 (sold)
'78 Honda cb750 (sold)
Offline KoŽstum
    • Motion Photos
« Reply #52 on: Mar 02, 2017, 19:12:13 »
Lunchtime progress... Rear wheel, engine, & driveshaft removed and brought inside. It's supposed to rain over the weekend and didn't want the exposed intake/exhaust ports open even if it will have a cover over it.
Los Gatos, CA
Honda z50 (sold)
Honda cb360 (sold)
Honda cb400f (sold)
Honda cb450 (sold)
Honda cb500t (sold)
Honda cb550 (sold)
Offline trek97
« Reply #53 on: Mar 02, 2017, 19:33:30 »
smear a little something on those fork tubes.
Offline KoŽstum
    • Motion Photos
« Reply #54 on: Mar 02, 2017, 20:56:18 »
Engine out and in the shop:
The driveshaft:
« Last Edit: Mar 02, 2017, 20:59:56 by MitchellSK »
Los Gatos, CA
Honda z50 (sold)
Honda cb360 (sold)
Honda cb400f (sold)
Honda cb450 (sold)
Honda cb500t (sold)
Honda cb550 (sold)
Offline KoŽstum
    • Motion Photos
« Reply #55 on: Mar 02, 2017, 20:58:52 »
Forks were pretty bad shape already when I got it:
« Last Edit: Mar 03, 2017, 03:53:09 by KoŽstom »
Los Gatos, CA
Honda z50 (sold)
Honda cb360 (sold)
Honda cb400f (sold)
Honda cb450 (sold)
Honda cb500t (sold)
Honda cb550 (sold)
Offline Maritime
« Reply #56 on: Mar 03, 2017, 09:43:28 »
Those will probably clean up better than you think. it looks like mostly surface rust.
Kamn
  • Guest
« Reply #57 on: Mar 03, 2017, 09:47:08 »
As long as the area of fork tube that travels through the fork seals isn't rusty, you will be ok.
some wd-40 and fine steel wool  should clean that up nice
Offline Ubergeez
« Reply #58 on: Mar 03, 2017, 10:27:24 »
Most excellent. We picked up 1 full gl500 complete, and 2 other gls, 500 and 650 plus lots of luggage cases and extra fairings in November.. ! Havent worked on them yet, as I have so many on the go right now! i love the shaft drive... no need to worry about a new chain!. But chains to have a special place in my heart.. Here are a couple bikes Ive built. One is a shaft Xv750 and the other Cb550!
Uber
Offline KoŽstum
    • Motion Photos
« Reply #59 on: Mar 09, 2017, 02:25:43 »
Sooooo... no pic but it's damn near bare frame. I want the swingarm off and I'm looking at the manual but not getting it. Do I just remove the spanner nut and then it comes apart or do I need to do something after/before the spanner nut? I see hex heads inside the nut but the doc's I'm looking at aren't clear on what to do.
I pulled the plastic plugs off both sides of the stamped frame, the air shock is off, the swing-arm is ready to drop if I can get the pivot out.
TIA
Los Gatos, CA
Honda z50 (sold)
Honda cb360 (sold)
Honda cb400f (sold)
Honda cb450 (sold)
Honda cb500t (sold)
Honda cb550 (sold)
