Author Topic: GL500 Silverwing Scooped for $125  (Read 18458 times)
Offline sbaugz
  • DTT BOTM winner
Re: GL500 Silverwing Scooped for $125
« Reply #60 on: Mar 09, 2017, 08:19:21 »
Sooooo... no pic but it's damn near bare frame. I want the swingarm off and I'm looking at the manual but not getting it. Do I just remove the spanner nut and then it comes apart or do I need to do something after/before the spanner nut? I see hex heads inside the nut but the doc's I'm looking at aren't clear on what to do.
I pulled the plastic plugs off both sides of the stamped frame, the air shock is off, the swing-arm is ready to drop if I can get the pivot out.
TIA
Did you get a service manual? Download one here and your question will be answered.
http://coodie.com/cx/GL500-650%20Service%20Manual%20-%20Full.pdf
Offline KoŽstum
    • Motion Photos
« Reply #61 on: Mar 09, 2017, 13:22:33 »
Awesome, that's not the same PDF I had, thanks.
Los Gatos, CA
1978 Honda Twinstar cm185cc: The Black Pearl project
1982 Honda GL500 Silverwing Project
Motion Photos On Facebook
'86 Honda VT700, just bought on April 29 '17
Honda z50 (sold)
Honda CB125... the original... long gone :(
Honda cb360 (sold)
Honda cb400f (sold)
Honda cb450 (sold)
Honda cb500t (sold)
Honda cb550 (sold)
'75 Honda cb750 (sold)
'78 Honda cb750 (sold)
Offline cxman
« Reply #62 on: Mar 09, 2017, 18:18:52 »
1978 CX650 Super Deluxe
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1974 kawasaki 350 bighorn
1983 GL1100 aspy full dress
1983 GL1100 Nekid
and a bunch of others
Offline KoŽstum
    • Motion Photos
« Reply #63 on: Mar 29, 2017, 20:55:47 »
Slow but steady progress, got some initial cleaning of a few pieces started at lunchtime.
Los Gatos, CA
Honda z50 (sold)
Honda cb360 (sold)
Honda cb400f (sold)
Honda cb450 (sold)
Honda cb500t (sold)
Honda cb550 (sold)
Offline KoŽstum
    • Motion Photos
« Reply #64 on: Apr 13, 2017, 01:26:36 »
Slowly cleaning nuts, bolts washers and more one by one BUT anyone have a lead on a new u-joint for the driveshaft?
Can't find a new u-joint anywhere. Swingarm bearings would be great too, I've seen them listed but not in stock anywhere. TIA.
All Balls for the fork conversion are in the mail :D
Los Gatos, CA
Honda z50 (sold)
Honda cb360 (sold)
Honda cb400f (sold)
Honda cb450 (sold)
Honda cb500t (sold)
Honda cb550 (sold)
Offline trek97
« Reply #65 on: Apr 13, 2017, 06:38:57 »
Neither sportland in urbana nor csmnl.com have them.  Both surprise me.   :o
surely they are not worn out.  Clean and repack them.
Or take them to your local Motion Industries.  They should find them.
Just dont screw them up.
Offline cxman
« Reply #66 on: Apr 13, 2017, 08:29:14 »
the u joint is not replaceable it is staked  and never was a service item you replace the drive shaft
if you are needing one pm me i will dig you one up
swing arm bearings are to be had   right from any bearing supply
30202 and the ID measures 17mm  you must use both cup and cone
size 30203 is 17x40x12
« Last Edit: Apr 13, 2017, 08:34:14 by cxman »
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1983 GL1100 Nekid
Offline KoŽstum
    • Motion Photos
« Reply #67 on: May 18, 2017, 11:15:15 »
Thanks for that cxman, I'll check get bearings.
Driveshaft rotates freely so I'll just clean it up and use it for now.
I got the rough engine cleaning done yesterday before I get crack it open.
Also gathered more parts... head bearings came in for the fork swap and a few other bits.
Sent from my XT1635-01 using DO THE TON mobile app
« Last Edit: May 18, 2017, 16:51:32 by KoŽstom »
Los Gatos, CA
Honda z50 (sold)
Honda cb360 (sold)
Honda cb400f (sold)
Honda cb450 (sold)
Honda cb500t (sold)
Honda cb550 (sold)
Offline KoŽstum
    • Motion Photos
« Reply #68 on: Jun 14, 2017, 16:44:15 »
Got the tach gear out at lunchtime for future seal replacement. Had trouble pulling it straight out but sticking the screwdriver through the visegrip jaws and prying against the wood block worked like a charm with a couple light taps.
Los Gatos, CA
Honda z50 (sold)
Honda cb360 (sold)
Honda cb400f (sold)
Honda cb450 (sold)
Honda cb500t (sold)
Honda cb550 (sold)
Offline KoŽstum
    • Motion Photos
« Reply #69 on: Jun 26, 2017, 16:32:38 »
FINALLY!!! After making tools and eventually buying the $40 repro that didn't work... but using the hex adapter I was able to get the whole spindle/castle nut assembly out without too much trouble and the swingarm is off so I can finally move forward some more. Now to either get the corroded nut off the f'n spindle. What a pain and delay this little step has been.
Los Gatos, CA
Honda z50 (sold)
Honda cb360 (sold)
Honda cb400f (sold)
Honda cb450 (sold)
Honda cb500t (sold)
Honda cb550 (sold)
