Author Topic: My first build - 75 Honda CL360 Scrambler  (Read 28297 times)
Offline ridesolo
  • You only bear responsibility for your own actions
Re: My first build - 75 Honda CL360 Scrambler
« Reply #30 on: Jan 01, 2017, 22:54:06 »
You only should buy another frame if it has a title, otherwise you put yourself into a whole different mess.  I guess if I were in your shoes right now I'd see about finding those rear engine mounts you cut off and hang onto them.  Not sure if they could be welded back on, but they may, at least be helpful to use as a pattern.  I'm pretty sure that you should be able to hang your engine back in w/ the other three sets of mounts and then find a welder/fab shop that could either weld your old mounts back in place or make and install replacements for you.  Ask around at garages and your local auto parts stores, somebody will be able to recommend someone who should be able to help you out.  If you have a local vocational/technical school you might be able to get their metal working department to help you.  In the future it might help to put some tape or a zip tie or something else on the pieces you want to keep so they don't "come off" by accident.  I speak from experience  :(  and I'm sure there are a bunch of other DTTers on here who have done the same thing.
“Fight on and fly on to the last drop of blood and the last drop of fuel, to the last beat of the heart.”
— Baron Manfred von Richthofen
Please check out:  http://www.VetTix.org
This is on a low simmer out in the shop:
'75 Honda CL378: http://www.dotheton.com/forum/index.php?topic=56547.0
This one is FINALLY done: (!)
'70 Rupp Roadster: http://www.dotheton.com/forum/index.php?topic=67459.0
Offline djsmiles
« Reply #31 on: Jan 01, 2017, 22:58:27 »
Thanks ridesolo, gd what's with the user names, my name is Miles. Anyway, I admit this was a complete dumnass stupid newby dumb thing to do. I should have tagged things from the beginning. Thank you for your recommendations.
Offline ridesolo
« Reply #32 on: Jan 01, 2017, 23:26:11 »
Thanks ridesolo, gd what's with the user names, my name is Miles. Anyway, I admit this was a complete dumnass stupid newby dumb thing to do. I should have tagged things from the beginning. Thank you for your recommendations. [/url]
Dumbass & newby maybe, Miles, but it happens.  A while back I was grinding a welded lug off of my frame that needed to be relocated.  Each side has a top and bottom lug and the top one on each side needed to be cut off, relocated, and then welded back on.  I got the tools of destruction out and went to work... only to discover after I had the first lug cut about 2/3 of the way through that I was cutting off the BOTTOM lug because the frame was sitting UPSIDE DOWN!  Dumbass?  Yup!  Newby?  Nope, just dumbass!   ;D We all live n learn and hopefully don't have to relearn and relearn and relearn too often!  Cory
Offline Rider52
« Reply #33 on: Jan 02, 2017, 01:08:34 »
If you can't find the mounts and you need a pattern, let me know. I have a frame here waiting the motor and I can make a pattern and measure distance if needed.
Regards,
John
Projects
74 Yamaha TX650
Sweep the Floor Project
3 Assorted Honda CL 72 scramblers in a million pieces
3 Harleys in constant state of sorrow and a Buell
1978 Yamaha Chappy 80 burning up the highway
Cut my motor in half Sportster to Shortster
Offline djsmiles
« Reply #34 on: Jan 06, 2017, 15:33:10 »
I called around town and got quotes anywhere from $75-150 but most guys said I had to bring in the frame with the engine mounted just to get a price. So the frame I found in Oklahoma sounded so much easier. I measured my frame and got an approximate weight and dcalled the local Mail-Mart in the sellers town and got a quote on shipping of $63 plus the cost to box it up. So $50 for the frame and approximately $70 to ship sounded way easier. I talked the seller into dropping off the frame at mail-mart for an extra $20 for his time. The next day i got a call from mail-mart telling me the cheapest is UPS at $166 plus $25 to package it plus taxes = $195. I almost crapped my pants. They said because they had to box it up and all that crap that it came out a foot longer than my measurements and 13 lbs. heavier. I could have drove down there and picked it up for a lot less money. So I will soon have another frame to work with. that mistake only cost me $265. oh well. live and learn. it's definitely not the most expensive mistake I've ever made.
Offline ridesolo
« Reply #35 on: Jan 06, 2017, 15:49:13 »
I called around town and got quotes anywhere from $75-150 but most guys said I had to bring in the frame with the engine mounted just to get a price. So the frame I found in Oklahoma sounded so much easier. I measured my frame and got an approximate weight and dcalled the local Mail-Mart in the sellers town and got a quote on shipping of $63 plus the cost to box it up. So $50 for the frame and approximately $70 to ship sounded way easier. I talked the seller into dropping off the frame at mail-mart for an extra $20 for his time. The next day i got a call from mail-mart telling me the cheapest is UPS at $166 plus $25 to package it plus taxes = $195. I almost crapped my pants. They said because they had to box it up and all that crap that it came out a foot longer than my measurements and 13 lbs. heavier. I could have drove down there and picked it up for a lot less money. So I will soon have another frame to work with, that mistake only cost me $265. oh well. live and learn. it's definitely not the most expensive mistake I've ever made.
Sure sorry to hear about all that, Miles.  Hopefully when you get that new frame you can settle in and get back to your project.  As a side note, don't trash your old frame.  The task of putting the engine from a XR600 into one of these frames involves actually relocating that lower frame crossmember and mounts so you may find that somebody might be interested in buying that frame from you for their CB/CL360 to XR600 project.   ;)
Offline djsmiles
« Reply #36 on: Jan 06, 2017, 16:05:03 »
Thanks, that's really good to know. maybe i'll put it up on ebay and see how much i can recoup.
Offline HerrDeacon
« Reply #37 on: Jan 06, 2017, 17:16:55 »
Great to hear you'll be back in business shortly. When you get the new frame I recommend just leaving the center stand mounts on the frame. They are not visible, don't weigh anything and allows you to put the stand on when ever you want which comes in handy when doing some maintenance.
Perry
1972 Honda CB350 K4 / 1978 Honda XL250S /1982 Honda MB5 / 2014 Honda CB500X
Offline revel.motorcycles
    • Revel Motorcycles Chicago
« Reply #38 on: Jan 09, 2017, 16:58:51 »
We all make stupid mistakes...mostly late night and in a rush.
Take your time and eventually learn to weld/fabricate.  ...or make friends with those who can!  ;)
I'm sure there are other parts to work on in the meantime!
Offline djsmiles
« Reply #39 on: Jan 16, 2017, 17:43:18 »
So I got the new frame and I've taken off the rear hoop and cleaned out the triangle, that's all I'm going to cut off. I've used paint stripper on the tank, twice, and found out that it's been repainted at some point because you can see the original stripes underneath. Acetone really did a good job removing the old liner, now I've filled it with vinegar hoping to remove what little surface rust remains. Oh and I replaced the tank cap gasket which was super easy once I took the spring thing out of the cap. And I've mailed the carbs off to PJ to be rebuilt.
