Author Topic: My first build - 75 Honda CL360 Scrambler  (Read 25280 times)
Offline djsmiles
Re: My first build - 75 Honda CL360 Scrambler
« Reply #40 on: Jan 22, 2017, 20:34:17 »
So the heat shield that I won on eBay for $50 looks really nice on the outside (except for a few tiny chrome blisters?) but the inside was really rusty so I soaked it in vinegar for almost a week and then scrubbed with low grit steel wool and what a difference! The tank came out looking really nice after the vinegar treatment but I left it alone overnight and now the surface rust on the inside is back. Same thing with the heat shield. the clean side was shiny just shortly before taking this pic. What can I do about the reoccurring surface rust?
Offline Sonreir
  • Moderator
  • Oregon
« Reply #41 on: Jan 31, 2017, 11:08:27 »
Get it coated with something as soon as it's clean.
For the tank, I like POR-15.
The heat shields can do with a touch of VHT paint, after being washed in soap and water and wiped down with alcohol. I'm about 99% sure VHT makes a clear coat, but color might not matter too much since it's on the inside.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #42 on: Jan 31, 2017, 13:09:24 »
POR 15 works great but if there aren't any pinholes it's not really worth the fuss. When it's fully de-rusted, I always swish about 12 oz of premix around to coat the inside.  Always keep the tank topped off with fuel while storing it to prevent further rust
Offline djsmiles
« Reply #43 on: May 24, 2017, 09:57:20 »
Hi, I'm getting my frame powder coated and need to get this rubber off the triple. What is this part called and how do I remove it
Offline Sonreir
  • Moderator
  • Oregon
« Reply #44 on: May 24, 2017, 10:16:52 »
Been a few years since I was working on my 360, but if I'm remembering things correctly, I think I ended up cutting mine off. The bearing race that's holding the rubber in place is pressed. In theory, you can just pull it off the stem, but I never had the correct tools to make it all happen.
Offline djsmiles
« Reply #45 on: May 24, 2017, 12:25:26 »
so it's called a bearing race? i'll need to make sure I can get a replacement before I go cutting it off. I don't find any searching eBay. do you know where I can get a new one?
Offline Sonreir
  • Moderator
  • Oregon
« Reply #46 on: May 24, 2017, 12:27:39 »
I would go with a tapered replacement from AllBalls. Not very expensive and well worth the money.
Offline djsmiles
« Reply #47 on: May 24, 2017, 12:37:27 »
oh yeah, i already ordered the All Balls bearings. so with that I don't need to replace this part, I can just cut it off and move on? Thanks for all your help.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #48 on: May 24, 2017, 12:40:27 »
Yup. You should be good to go. You're going to need to remove it for the AllBalls replacement anyway.
Offline djsmiles
« Reply #49 on: May 24, 2017, 14:19:31 »
Maybe you could help me here with the bearing kit. I ordered All Balls 22-1011 which says it fits my bike but I see All Balls 25-1319 which also fits my bike. Am I confused or which one do I need?
