Author Topic: My first build - 75 Honda CL360 Scrambler  (Read 25277 times)
Offline jag767
    • Kinesis Moto
Re: My first build - 75 Honda CL360 Scrambler
« Reply #50 on: May 24, 2017, 14:45:44 »
Maybe you could help me here with the bearing kit. I ordered All Balls 22-1011 which says it fits my bike but I see All Balls 25-1319 which also fits my bike. Am I confused or which one do I need?
One is probably the top race the other is the bottom.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #51 on: May 24, 2017, 15:45:02 »
Usually comes in a kit. Check all balls website for fitment.
Edit: from all balls website: Steering Bearing kit   22-1011
1319 is a wheel bearing kit.
I use a small dremel wheel and cut diagonally across the lower race. Once you get most of the way through, a hammer and drift will usually help it pop off without damaging the stem underneath.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #52 on: May 24, 2017, 15:47:12 »
Yup. Exactly what I did, too.
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
Offline cxman
« Reply #53 on: May 24, 2017, 18:43:45 »
hold it on a block of wood and use a screwdriver to tap down on the seal/race it will come off
1978 CX650 Super Deluxe
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1974 kawasaki 350 bighorn
1983 GL1100 aspy full dress
1983 GL1100 Nekid
and a bunch of others
Offline djsmiles
« Reply #54 on: Jun 03, 2017, 14:18:10 »
So I've been scrubbing on the engine trying to get the oxidation and discoloration off. I've tried the recommended products with scrubbing pads and steel wool which take off some but not all. The dark spots really bother me. Any suggestions?
Offline Rusnak_322
    • STUNT BIKE
« Reply #55 on: Jun 04, 2017, 15:31:31 »
What's your plan? If you leave it uncoated, oxidation will come back right away. If you clear coat it, they all ways seem to yellow on motors.
I have had good luck painting my motors with aluminum high temp paint. If will give you the uniform look and it lasts.
Offline djsmiles
« Reply #56 on: Jun 05, 2017, 09:13:58 »
I would really like to leave it looking like it was from the factory. Bare metal. I don't want a black engine. I think it makes the cool details disappear
Offline Rusnak_322
    • STUNT BIKE
« Reply #57 on: Jun 05, 2017, 09:38:38 »
Most modern motorcycle motors came painted from the factory. Not sure on the 1970's bikes.
Here is my old 360 motor - see the build thread in my sig.
And here is my Moto Guzzi
after soda blasting -
Short of completely disassembling and having the parts vapor blasted, this is the easy and cheap way to get it. there are different color, I played with stainless & aluminum colors and different brands to make it look more like it is not just spray bombed.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #58 on: Jun 05, 2017, 13:00:15 »
Rustoleum Aluminum colored enamel ends up looking pretty good, I think.
Offline djsmiles
« Reply #59 on: Jun 05, 2017, 13:05:12 »
those engines look awesome. I didn't realize most engines were painted. I just got the frame back from being powdercoated and am really anxious to get the engine installed but now I'm going to have to pick out colors to paint the engine before putting it back in the frame. thanks for the info!
