Author Topic: CB 450 twin. I said I needed a project  (Read 8113 times)
Offline john83
Re: CB 450 twin. I said I needed a project
« Reply #20 on: Dec 04, 2016, 22:49:54 »
Don't be a tool John. Jb weld may be good enough for airplanes, but don't bring that noise into the custom motorcycle scene, you savage.
Come on man. We are true professionals here in airplane land. We would use a mixture of Liquid Nails, two part epoxy and dirt.
Offline Hurco550
« Reply #21 on: Dec 04, 2016, 22:51:02 »
Come on man. We are true professionals here in airplane land. We would use a mixture of Liquid Nails, two part epoxy, chewing gum, twine and dirt
Fixed it
~ bradj
Offline cxman
« Reply #22 on: Dec 05, 2016, 07:41:04 »
john
i thought you had to put a coat of zinc chromate on it first
we had to when doing a float repair??
1978 CX650 Super Deluxe
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1974 kawasaki 350 bighorn
1983 GL1100 aspy full dress
1983 GL1100 Nekid
and a bunch of others
Offline cardinal
« Reply #23 on: Dec 06, 2016, 00:10:19 »
While I wait for my cam chain tool to arrive I was wondering if anyone has seen this problem before on one of these engines: It looks like the front (exhaust) lower guide roller somehow came loose and was spinning on the cylinder head till it eventually wore right through and oil shot all over the place. Is this a sign that I'll need to do a complete engine overhaul? Wondering about the aluminum that ended up in the engine...
Thoughts?
« Last Edit: Dec 06, 2016, 00:12:29 by cardinal »
Offline cxman
« Reply #24 on: Dec 06, 2016, 08:11:44 »
check the centrifugal filter and see if it caught it
i have welded a few of those up where i just got the head to fix
and other than guides and a chain i dont think they took the bottom end apart
its so easy to split i would not do it without a through clean and inspection
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1983 GL1100 Nekid
Offline frogman
  • '74 CB360, '71 CB450, '75 CB550SS
« Reply #25 on: Dec 06, 2016, 09:42:53 »
Complete overhaul is based on more than just a hole in the side of the engine, however it would make me take a hard look at most of the oil passages in the crankcase and the head to make sure things aren't plugged up. The oil also passed through the pump prior to getting into the filter so you should certainly take a look at it.
Its worth splitting cases as well, just to make sure your transmission is in good shape. That one shouldn't have the chain oilier and fork issues but its worth looking at.
Offline cardinal
« Reply #26 on: Dec 09, 2016, 23:52:14 »
got my chain tool and popped the top off. Here's a pic looking into the cylinder head where the wear was. See that piece of metal on the top? It was just hanging out there on that little shelf. It's not aluminum, I picked it with a magnet. Not sure where it came from.
The second pic is the chain tensioner that made the hole. You can see that the bracket that was holding it in place snapped off.
Offline cardinal
« Reply #27 on: Dec 10, 2016, 02:14:44 »
And after further inspection, you can see that the piece of metal is a missing chunk of the cam wheel bracket. There is a piece missing near the top bolt head in the 2nd pic. Did a search on eBay, they might be hen's teeth.
Offline cxman
« Last Edit: Dec 10, 2016, 08:48:41 by cxman »
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1983 GL1100 Nekid
Offline cardinal
« Reply #29 on: Feb 20, 2017, 00:43:54 »
I'm still here! I had a busy winter at work with travel and the holidays I haven't had any time to spend on the bike. I did manage to buy a replacement jug and cam guides from jag767 (thanks!). Today I stripped the head down and realized three of the valves are completely bent. So now I'm on the prowl for the least expensive option I can find. I've been going back and forth about whether or not to take the rest of the bike apart and do a full rebuild. It's pretty unlikely I'll have the motor out again any time soon, so I'm thinking I might go ahead and strip the frame and make some adjustments while it's easy. I'll probably add a frame loop and get rid of some of the extra tabs and bumps.
