Author Topic: Filling dent in frame before powdercoating  (Read 1707 times)
Offline o1marc
    • Creative Candy Powder Coating
Re: Filling dent in frame before powdercoating
« Reply #10 on: Dec 21, 2016, 17:16:47 »
JB Weld will work nicely and will be cheaper to buy in smaller quantities than the All Metal or Lab Metal products that run over $40. Use the regular JB Weld, the quick set will not work with the PC temps. Give your surface the roughest sand blast "tooth" you can in the dented areas. Once applied you can speed cure the JB Weld at 90 for an hour in the oven. Regular type Bondos will shrink and pop in the oven.
