Author Topic: Nannos Hotrod Turbo TR1.1 (XV1000)  (Read 3118 times)
Offline der_nanno
  • Faster!
    • Greasy Greg
« on: Dec 31, 2016, 19:16:26 »
I've promised, I open a thread on my turbo and it's probably one of the last things I'll do in 2016, but hey... rather late than never, right?
Well to be honest, the whole story started about two years ago, when I "bought" the bike for a crate of beer. Mainly because the engine was seized (the p.o. had pulled the carbs and then part of the roof of his workshop collapsed) and well... just check out the pictures, which make the bike look A LOT nicer than it actually was. Lots of parts simply turned into dust at the lightest touch.
Technical specs of this one:
XV1100 crank to bring it up to 1063cc
Stock XV1100 heads with polished valves and slightly ported (just taken off the casting imperfections really)
modified TR1-clutch or maybe a modified XV1100 clutch (that would allow an extra 9th disk)
There's actually two turbo setups you can see in the pics and a third one to be built soon.
1) The blow-through-setup consists of stock XV1100 Mikuni carbs (because they have very heavy slides and external floatchamber vents), a TD04-13G turbo (out of a Subbie Forester), Intercooler out of a Ford Focus Turbo Diesel, fuel pump BMW 528i E39, fuel pressure regulator: a cheap one made out of Chinesium - I've never quite finished this setup due to some issues with the TD04, but quite a large portion of it will be used for the new setup with a GT1548
2) A rather butch and simple draw-through setup with a Chinese Garrett T3 copy and a Mikuni VM44 on a 2in1-manifold. There's absolutely nothing fancy about this setup, but it worked until a bearing failure stopped the turbo dead.
So here we go:
Then I had some flanges cut for the first turbo-setup:
And this is pretty much, where the build for the first version of the turbo setup ended:
Then I started on the draw-through setup:
And that's the headers sorted:
Clocked the turbo and took off some measurments:
Used an old brake-line to work out the correct length: (35cm)
Getting the rear header right:
The finished product (admittedly the front-downtube is only tacked at that point, as I ran out of time)
And that's what she looked like in the end:
And there she's runnin':
Now you have to be patient with me as I am currently building a new sidecar for me (XS750 with a KMZ/Dnepr K750 sidecar) and well, I can't "just" build a sidecar... (and I am way behind schedule, but that's how life goes!)
I admit I've left out some bits and those can be found on my blog in the following posts (as I said, this has been going on for two years, even though only a fraction of the time was spent on building the turbo setups, but I mainly used the bike for building exhausts for my own and other TR1s/XV750ies)
http://greasygreg.blogspot.co.at/2016/0 ... art-1.html
http://greasygreg.blogspot.co.at/2016/0 ... bling.html
http://greasygreg.blogspot.co.at/2016/0 ... g-out.html
http://greasygreg.blogspot.co.at/2016/0 ... er-of.html
http://greasygreg.blogspot.co.at/2016/0 ... s-are.html
http://greasygreg.blogspot.co.at/2016/0 ... alves.html
Cheers,
Greg
« Last Edit: Feb 14, 2017, 16:57:03 by der_nanno »
My Blog:
Offline der_nanno
  • Faster!
    • Greasy Greg
Re: Nannos Hotrod Turbo TR1.1 (XV1000)
« Reply #1 on: Jan 22, 2017, 06:08:17 »
Thx to Beachcomber for reminding me of the existance of CT20 turbos (and the fact that some of them in fact truly ARE carbon sealed, I had a little poke around the mighty bay of "e" and guess what - I found an early CT20 turbo in good nick for the right price. The whole thing isn't gonna be quite as straight-forward as I hoped initially as you can't clock CT20 turbos and feed and drain are on the same side. Those aren't real show stopper, but it means a little obstacle that I will be forced to work around.
« Last Edit: Feb 14, 2017, 16:59:49 by der_nanno »
My Blog:
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #2 on: Mar 15, 2018, 13:12:52 »
I guess, this thread has lain dormant for a sufficient amount of time, so I might as well, start it off once more.
Now I had a rather nice turbo setup on the bike, unfortunately said turbo died. Then I got my dirty ol' paws on quite a nice Eaton M45, but unfortunately, no matter how I twisted and turned it, it would have meant raking the headstock to make the supercharger fit between front-wheel and engine.
So when a friend told me, that his old Jeep Wrangler with the (in-)famous IL-6 needed a supercharger I sold said Eaton M45 and made a few adaptors for him.
Fast forward a couple of weeks (months actually) and I was able to get my hands on a VW-branded Eaton M24 out of a 1.4TSI Polo.
Due to the internal step-up gears with a 1.93:1 ratio, this little blower actually displaces 46.3ci per revolution, which means it actually puts out more air than the old M45, even though at the cost of producing more heat at the same time.
I already have sketched up an adaptor for the crank, but I have to get a LH-M8 tap (easy) and a LH M8x40 bolt (the actuall challenge as I found out) to secure said adapter to the crank.
Bit more stuff on my blog: http://greasygreg.blogspot.co.at/2018/03/the-turbo-tr1-maintenance.html
My Blog:
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #3 on: May 10, 2018, 02:57:49 »
Now being a curator of all manner of things being special, i.e. being a hoarder of my old projects, I still had an earlier set of turbo headers kicking about and as I recently had to wait for some spare parts to be delivered for the new TR1 engine, I did some measuring on a flange, only to discover that said flange could be repurposed.
Now almost nothing drills as "nice" as work hardened stainless steel, so drilling three holes took the better part of two hours and an ungodly amount of swearing.
But after a bit of dressup with an angle grinder and a flap-disk, the result is almost presentable.
The turbo in the picture doesn't only LOOK, but actually IS tiny. It's a GT1540-something, out of a Opel Astra 2.0 Turbodiesel, which makes a bit shy of 100hp.
So why go down from a GT30 to GT15? The answers are: instant boost and I had it already sitting on the shelf gathering dust. As some of you may, is this the end to the supercharger project? No, but I can get this buttoned up and working in a matter of days and then have some fun on it and the supercharger is a genuine engineering challenge and will require a bigger time investment than I currently have available. (And the everyday engine is more important for obvious reasons...)
More-pix here: http://greasygreg.blogspot.co.at/2018/05/the-turbo-tr1-gt15-turbo-build-part-1.html
My Blog:
Offline Brodie
  • Gold Coast, Queensland
« Reply #4 on: May 10, 2018, 08:40:55 »
Twin charge sounds good.
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #5 on: May 10, 2018, 09:06:11 »
Ultimately I want to register this heap for road use, so Supercharger it is... The authorities are straight from spoil-sport-land.
My Blog:
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #6 on: Nov 25, 2018, 16:06:58 »
Nobody asked for this and yet still... here goes: I restarted the turbo project and want to implement quite a few of learnings I took from the last setup. Most importantly, everything should be rubber mounted or have slip joints, so it can extend and contract depending on temperature. Only thing: The space between those cylinders hasn't changed so some creative thinking was due.
No matter how much space you start out with, add a turbo to the equation and all the bits fight for exactly the same space under the tank.
Let's add several hours of trying and failed attempts and ultimately giving in and fabricating the missing bits from piecuts. Now I really don't like pie cuts, because pie-cuts are for hipsters. Even though in this case that's probably the only legit use-case for them as you couldn't bend the tube tight enough.
No dressing up here, but the result is really rather compact.
And that's the intermediate result as of this afternoon. Still quite a few bits to sort out, e.g. how to make a joint to seal the turbo nicely to the manifold and ideally give it some level of flexibility. Also the rubber manifolds have to be shimmed a bit as the manifold warped a bit during welding.
The full blog-post: https://greasygreg.blogspot.com/2018/11/the-turbo-tr1-new-manifold-part-3.html
My Blog:
Offline JustinLonghorn
« Reply #7 on: Nov 27, 2018, 15:00:59 »
Rad. I'm on board.
Into The Sunset, CB750 build
TT500 the Animal
Offline der_nanno
  • Faster!
    • Greasy Greg
« Reply #8 on: Dec 06, 2018, 18:29:38 »
Teaser...   8)
My Blog:
Offline hooligan998
« Reply #9 on: Dec 07, 2018, 00:48:43 »
Yeeehaaaww!  I'm in.
