Author Topic: 74 Cb360 Engine Noise  (Read 1326 times)
Offline tj10packers
« on: Jan 24, 2017, 18:24:23 »
Was wondering if any 360 owners could help me identify what a healthy engine should sound like.
Background:
Bought this thing as a basket case and cleaned it up over the past few months. Trying to get it put back together so I can learn how to ride on it and get a feel for how much time and $$$ a cafe/brat project will take.  Haven't made really any big mods just yet but it's been fun learning how these bikes were built and I'm chompin at the bits to have it ready for this upcoming season.  Would eventually like to tear it down again and do a proper engine rebuild,  and give the bike a nice brat tracker touch.
Here's how she sounds now.  Not sure if the cam chain needs to be loosened... the original cam chain tensioner set bolt was broken so I've got a large 8mm screw and some washers to manually adjust the tension.  The end of the video is me figuring out that the missing kickstarter return spring is causing the grinding noise.
-T.J.
Offline irk miller
Re: 74 Cb360 Engine Noise
« Reply #1 on: Jan 24, 2017, 18:36:09 »
That cam chain is loose as hell.  This is not a bike to skimping on the tensioner mechanism. Have you run through the procedure in the FSM?
Offline tj10packers
« Reply #2 on: Jan 24, 2017, 18:46:42 »
Yes I've attempted to do it but I believe the PO either broke the bolt or ruined the threads in the case.  When you go to tighten it down there's just a little resistance then it starts to spin freely.
This bolt should have a smaller diameter portion at the very end right?  The part that sits in the groove of the tensioner push bar, at least that's how it looks in the parts illustration.
Sent from my SM-G900V using Tapatalk
Offline tj10packers
« Reply #3 on: Jan 24, 2017, 18:51:42 »
What ive done instead is use a long 8mm screw in place of the oil check bolt-which I heard of a few people doing on the forums.   So now I can manually position the pushbar but I'm not sure how loud the valves and chain are normally.
Offline irk miller
« Reply #4 on: Jan 24, 2017, 19:15:39 »
That's definitely a loose cam chain.   You can tell by the noise changing pitch with revs.
Offline tj10packers
« Reply #5 on: Jan 24, 2017, 19:20:09 »
Thanks Irk.  I'll tighten it up a bit and post another video of it running after I find a kickstarter return spring.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #6 on: Jan 24, 2017, 19:39:36 »
You need to make sure you have the engine at the correct position, I believe the LT mark when the left cylinder is on the compression stroke, and then you loosen that locking bolt. The tensioner plunger is spring loaded and should automatically adjust. If that isn't doing it, then you either have a stretched cam chain, bad springs or a bad tensioner. Does this engine have the two punch marks on the engine no. plate?
'78 Honda z50 - http://www.dotheton.com/forum/index.php?topic=76059.0
Offline tj10packers
« Reply #7 on: Jan 24, 2017, 20:10:54 »
Yes the recall has been done,  it was stamped and had the new style tensioner holder.  I will go through that procedure again.  Even though I'm no longer using the set bolt which screwed in perpendicular to the push rod, but rather a screw that butts up against the end of the pushrod it serves the same function right?
I played with the tensioner mechanism when I had the top end apart to try and understand it better.  I applied some pressure on the bottom holder of the tensioner that is attached to the horse shoe. I could get it to move down in the engine and stay down,  and also measured to find the pushrod was moving towards the front of the case.   Then I would use a punch and lightly tap the pushrod into the case and watch the horse shoe push the tensioner up. At any position of the pushrod I could depress the lower tensioner holder about an inch or two and it would spring back into place without moving the push rod, which is normal right?
With the pushrod pushed into the case, and the tensioner sitting in the engine on its holder, the top of the tensioner sat between half an inch and an inch above the mating surface, so I know that it was applying tension to the chain as I bolted the top holder in.
I just don't understand how you can loosen the set bolt with the engine in any configuration without the tension of the chain pushing the push rod to a point where you still have any tension left on the chain.
Thank you guys for your responses! Sorry for the short novel...
Offline irk miller
« Reply #8 on: Jan 24, 2017, 20:17:29 »
90 passed the LT mark
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #9 on: Jan 24, 2017, 20:58:00 »
Yeah, that. The important thing when adjusting the cam chain is that all 4 of the valves are slack, which happens 90 degrees after LT. If you are saying you were able to easily push down the cam chain tensioner plunger then the springs might be out of spec, or only one of the two springs made it back in. It should take quite a lot of force to push it down.
