Author Topic: Build Project 1978 GS550  (Read 11632 times)
Offline Urban Monk
    • Urban Monk TV
Re: Build Project 1978 GS550
« Reply #20 on: May 22, 2017, 13:57:08 »
Episode 15...
Wishing you happiness, joy and laughter (which shouldn't be difficult since you all own motorcycles).
Offline Urban Monk
    • Urban Monk TV
« Reply #21 on: May 30, 2017, 13:41:43 »
Episode 16. Valve removal, value lapping, cleaning carbon deposits, rust removal from chrome exhaust using vinegar.
Offline Urban Monk
    • Urban Monk TV
« Reply #22 on: Jul 12, 2017, 20:18:30 »
Episode 17...
Offline Urban Monk
    • Urban Monk TV
« Reply #23 on: Jul 12, 2017, 20:19:40 »
Episode 18... Installing camshafts.
Offline Urban Monk
    • Urban Monk TV
« Reply #24 on: Jul 19, 2017, 14:38:10 »
Episode 19. Polishing aluminum engine parts and doing valve clearance check post-valve job. Difficult because existing shims all too thick after lapping valves so can't "do the math."
Offline Urban Monk
    • Urban Monk TV
« Reply #25 on: Aug 08, 2017, 20:05:03 »
Episode 20. Finalizing valve shim clearances and polishing the stator cover.
Offline Urban Monk
    • Urban Monk TV
« Reply #26 on: Aug 16, 2017, 18:33:48 »
Episode 22. Oil pan, clutch cover and a little more aluminum polished.
Offline Urban Monk
    • Urban Monk TV
« Reply #27 on: Aug 20, 2017, 20:45:25 »
Episode 23. Generator cover and starter clutch gears.
Offline hillsy
« Reply #28 on: Sep 06, 2017, 20:51:14 »
Hey - been enjoying your videos  :)
I was going to comment on your YouTube channel but couldn't log in for some reason.
Anyway, you are missing at least one locating dowel / pin for the stator cover. There are 2 larger holes up near the top of the cover and corresponding holes on the crankcase where the dowels reside. You need them to ensure the cover is perfectly positioned so the stator works properly. Not 100% if they ran two dowels or just one, but you need at least one.
Keep up the good work - the motor looks nice.
Offline Urban Monk
    • Urban Monk TV
« Reply #29 on: Sep 11, 2017, 12:26:33 »
You were the only one who caught it!!! Good job. You may know by now that caught the error myself and rectified in the following episode. Thanks for looking out for me!  :)
