Author Topic: xs650 Sumotrack  (Read 25236 times)
Offline Rat_ranger
xs650 Sumotrack
« on: Feb 19, 2017, 18:10:23 »
Ok, I just picked up a 78 xs650 yesterday for $100.  Plans are to make a street tracker.  It will get an fzr400 3tj swingarm and monoshock as I already have the swingarm.  I actually have 2 of them.  Probably get a set of USD forks, I do want spoked wheels on it.
Engine will be kick only, at some point I want to rephase for the sound.
« Last Edit: Apr 19, 2017, 19:42:15 by Rat_ranger »
Offline Rat_ranger
Re: xs650 tracker
« Reply #1 on: Feb 23, 2017, 19:39:24 »
1st step is to fix the reason it was parked over 10 years ago.  So rather than fix the stock charging system I am upgrading to a PMA set up.  Parts are coming in so last night at work I went over to the waterjet and made the mount plate to use a banshee stator mount.
Offline Rat_ranger
Re: xs650 tracker
« Reply #2 on: Feb 26, 2017, 00:30:13 »
Some progress was made today.  First did an actual compression test 110psi on both cylinders.  Carbs are cleaned and installed.  Exhaust was removed, banshee flywheel lightened in my lathe and thats where I stopped.  Ordered a flywheel puller as the right one is cheaper than a 3 jaw locally.  So now to look over the manual that arrived, clean and set the points and get ready to finish the PMA conversion.
Offline Rat_ranger
Re: xs650 tracker
« Reply #3 on: Mar 11, 2017, 16:45:13 »
Small update, finished the PMA swap, put some fuel in the carbs and it fired on the second kick.
Offline Rat_ranger
Re: xs650 tracker
« Reply #4 on: Mar 18, 2017, 12:46:58 »
Did some work on the bike when the sun came out the other day.   Complete different look in a couple hours.
Offline Rat_ranger
Re: xs650 tracker
« Reply #5 on: Mar 31, 2017, 17:51:58 »
New swingarm fits.  It ia from a fzr400rr 3tj.  Aluminum, beefy and lightweight.
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #6 on: Apr 19, 2017, 19:46:38 »
Need to get a few pictures, but zx6r forks are on the way, CB550 front hub has started the machine work to be used with the big piston forks.  Intake manifolds for the EFI conversion are started, need to do some layout and get them on a mill.
Finally I decided to call this the Sumotrack.  Reason being is it will have street tracker styling, but it will have fairly modern suspension with 17" wheels.
Offline VonYinzer
Re: xs650 Sumotrack
« Reply #7 on: Apr 19, 2017, 22:33:14 »
Following along. Neat stuff!
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #8 on: Apr 20, 2017, 13:20:00 »
Thanks, it'll probably take a while since the money for parts comes from overtime.  But having a lathe there are some parts that will be made from material out of the scrap pile, like the intakes.
Online canyoncarver
  • 'hacking is learning'
Re: xs650 Sumotrack
« Reply #9 on: Apr 20, 2017, 13:28:49 »
Neat.
73' The Commando
YZF750/1000R The Fly
KZ 750 Twin
ZRX 1100
KZ400 The Rabbit
KLR650, 69' Norton P11 Ranger, a 65' Atlas, a 60' BSA scrambler, 93" shovelhead chop, an 86' FXR, and an F9 Bighorn
more YZF750R's, more KZ's, a Zephyr750...and the ever unfinished 75' CB550 cafe.
