Author Topic: xs650 Sumotrack  (Read 25689 times)
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #70 on: Oct 26, 2017, 09:29:58 »
No problem.  If you haven't done anything like this before I would recommend getting the cheapest hoop you can find and do a practice run.   It isn't that it is really hard, it is more of how easy it is to mess it up.   But really that can be said of most fabrication.
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #71 on: Oct 29, 2017, 20:40:04 »
I have tires! Unfortunately I made a rookie mistake and pinched the front tube.  So I have to get a new tube and pull the tire half way off.  I am going to make a tire changer, I figure for the price of even a cheap one I can do better.
Offline Pete12
Re: xs650 Sumotrack
« Reply #72 on: Oct 29, 2017, 23:08:21 »
Wow, looks great with the rubber in place.
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #73 on: Oct 29, 2017, 23:32:19 »
Thanks! I'm pretty happy with the tire and wheel size.  Front is a 120/70r17 on a 3.5" rim, rear is 150/70r17 on a 4.25" rim.  Tires are shinko 705s.
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #74 on: Nov 04, 2017, 22:57:44 »
Semi related to the build I got a second engine the other day.  Not much done on the bike as its mostly waiting on funds.
Offline beachcomber
  • TJ - Beachcomber
Re: xs650 Sumotrack
« Reply #75 on: Nov 05, 2017, 10:04:57 »
Great work to date .. keep pix coming !
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #76 on: Dec 02, 2017, 18:50:12 »
So I took advantage of diyautotune having a black friday sale and ordered a microsquirt.  I have a plan to do an in-tank fuel pump and have been working on throttle bodies.  After checking suzuki sv650, hyosung gt650, triumph bonneville, and k1 gsxr600 ITBs, I decided to use the ones from the gsxr as they fit the BS38 carb mounts.  Now, the apacing is pretty far off, but they are very easy to respace.
 I will be mounting them "upside down"  for easier throttle cable routing.  So the injectors will be on the bottom.  The microsquirt will fit under the seat.  The only thing I have to figure out is where to mount the coils.  I'm going to use LS coils as they are fairly small, have a built in ignitor, and you can find them about everywhere.
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #77 on: Dec 09, 2017, 19:25:20 »
Slight update, got a new front tube and installed it successfully.  So now both tires hold air.  Other update is I started making the block off plugs for the secondary butterflies that the gsxr used.  So nothing big looking to show change, but there is slow progress.
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #78 on: Dec 15, 2017, 21:33:25 »
I was busy at lunch today.  Turned some 3" aluminum into stacks that'll let me run 3" ID uni pods.
« Last Edit: Dec 15, 2017, 21:36:46 by Rat_ranger »
Offline CrabsAndCylinders
Re: xs650 Sumotrack
« Reply #79 on: Dec 16, 2017, 01:29:20 »
Those stacks look beautiful. Are they a turned shape and length?
Lighter, Quicker, Faster.
