Author Topic: xs650 Sumotrack  (Read 25688 times)
Offline crazypj
Re: xs650 Sumotrack
« Reply #90 on: Feb 11, 2018, 12:35:56 »
It's never a learning curve building 'custom' bikes, it's a cliff  ;D
Best thing I ever overheard
Brian Morgan, 1982
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #91 on: Feb 11, 2018, 12:44:22 »
Very true, little things you overlook will stop you cold.
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #92 on: Feb 17, 2018, 22:45:29 »
Well 2 pictures of todays work.  The rotor spacer is complete for the rear, and the exhaust will be ready for ceramic coatimg next week.
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #93 on: Feb 24, 2018, 21:27:34 »
Rear rotor is mounted, custom throttle cables are made, electronics tray is underway.  And no picture but the header is out for ceramic coating.
Throttle cables are a mix of motion pro revolver at the handlebars, and ducati st4 I think at the throttle bodies.  The cable ends were turned out of some brass rod I had sitting around and all soldered together using bicycle cable.
Offline crazypj
Re: xs650 Sumotrack
« Reply #94 on: Feb 24, 2018, 23:30:25 »
I use a lot of bicycle brake inner cable for throttle cable, same diameter wire plus outer sheath is available in various colours.
I've also used lengths of heat shrink for brake line and clutch cable covers so everything more or less matches  :o
« Last Edit: Feb 24, 2018, 23:32:32 by crazypj »
Brian Morgan, 1982
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #95 on: Feb 25, 2018, 00:00:11 »
Nice thing about the bicycle inner is you can get a 10 pack of really long ones on amazon for about $10.  So with modifying the revolver outer with part of a used ducati cable I have under $20 in a custom cable.
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #96 on: Mar 01, 2018, 11:32:10 »
Made a small but needed part this morning.  Longer sprocket bolts for the kz750 hub.  Looked around and no one seems to make them, but I have to space the sprocket out.  So I pulled some hardened 17-4 stainless out of the scrap bin and got busy.
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #97 on: Mar 01, 2018, 23:34:39 »
Bolts are good, cut down the original 530 sprocket as a spacer, and now the sprockets are within .01" of perfect alignment.
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #98 on: Mar 03, 2018, 09:41:29 »
Headers are back from ceramic coating, and clutch slave is done.
Offline Rat_ranger
Re: xs650 Sumotrack
« Reply #99 on: Mar 03, 2018, 15:05:00 »
Plate mount and second tail light mounted.  My reasoning for running 2 tail/ brake lights, the one sunk into the hoop is not marked DOT and I'm iffy on the brightness, the one on the plate mount is DOT marked and gives that much more visibility.  The plus side is if I pull 2 bolts the entire plate mount comes off, cleaning up the tail if I ever take it to a show.
