Author Topic: 1990 Suzuki DR350 Medusa Transducer Hellride  (Read 13847 times)
Offline irk miller
Re: 1990 Suzuki DR350 Medusa Transducer Hellride
« Reply #70 on: Apr 07, 2017, 10:44:04 »
You ride it yet?
Not yet.  I got it running about 10pm last night.  The last time I test rode a dirt bike that late the cops drove by.  I was doing laps in the back yard, drunk and raising hell, so no surprise there.  Haha.  I plan to ride it today- just need to clean the tank.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #71 on: Apr 07, 2017, 11:17:08 »
I need to get a supertrapp for the XL...
In other news when do we start converting all the old XLs and 360s to needle bearings?
Offline irk miller
« Reply #72 on: Apr 07, 2017, 11:43:51 »
I've already bought the bearings and material to convert the 360(378).  I'll be taking it apart to do the work once I get the DR and BMW finished. I also have two XL motors (a 175 and 250) that will get the test.
Offline cxman
« Reply #73 on: Apr 07, 2017, 12:24:20 »
i have a 250 head waiting
1978 CX650 Super Deluxe
1979 XS1100 Special
1974 xl350
1983 cx650 Custom
1973 cb750
1980 cb750
1981 cb650
1982 cb900 c
1974 kawasaki 350 bighorn
1983 GL1100 aspy full dress
1983 GL1100 Nekid
and a bunch of others
Offline JAGspeed
« Reply #74 on: Apr 10, 2017, 23:30:15 »
Great bike, like what you did with the head. I've got a 99 DR350 Dirt model but made it street legal. I did tons of mods to mine, DRZ400 piston big bore (453cc). Keintech airbox, 37mm FCR carb. porting. DR350SE stator and CDI. My bike rips now.
The reason I built my motor was my original motor had a catastrophic failure. These bikes are notorious for the pin in the counterbalance gear to come loose and push trough the hole in the crankshaft that lines it up. This causes the crankshaft and counterbalance to hit and blows it through the cases. Jesse at Keintech Engineering has a fix for it but you need to send him the counterbalance gear and crankshaft. There are plenty of DR's that never have this issue but it SUCKS when they do. If you ever tear it down you should definitely get it done.
Good luck with your build.
XS650 Tracker build Mod Style: http://www.dotheton.com/forum/index.php?topic=48134.0
Cafe XV920R Mega-Build: http://www.dotheton.com/forum/index.php?topic=55864.0
CB750 Resto-Mod build:http://www.dotheton.com/forum/index.php?topic=58358.0
Offline irk miller
« Reply #75 on: Apr 10, 2017, 23:53:57 »
I haven't read about the counterbalance issue, yet. Thanks for the warning. The plan is to street this one too. On that DRZ swap:  Was it a DRZ sleeve or one from LA Sleeve? I have an 89mm piston to do a 441, but no sleeve. I hoped the Eiger 400 would give me enough meat, but they don't. I found a DR350 jug at a salvage that happened to be re-sleeved and bored to 86mm. I have no idea what piston they used for 86mm. Unfortunately, they turned the base of the sleeve down to 89mm, so now I search for another. It's been suggested that an XR400 big bore sleeve, which utilizes an 89mm piston might work.
Offline JAGspeed
« Reply #76 on: Apr 11, 2017, 13:02:45 »
My cylinder was an LA sleeve modification. The DRZ piston is 90mm and did require me to machine the head some to keep the compression down so I could run pump gas.
If you look a Kientech's website there is some info on the counterbalance pin. Jesse is the DR guru there. He is an older guy with tons of info. and likes to talk. He told me that he ad an aluminium sleeve for  the big bore kit that ran a little cooler. I know he has the big bore gaskets also.
Offline irk miller
« Reply #78 on: May 02, 2017, 01:29:17 »
The bike was bought with stock hardware missing for the side covers so I machined some washers out of delrin...
The plastics are actually in decent shape except for yellowing on the tank and oxidation on the fenders and side covers. How I like to restore it is wet sand with 1000 grit paper and soapy water. In this case, Clorox cleanup for white plastic. Then polish with Meguiers Ultimate Black plastic restorer. More on the tank later...
Offline Mr.E
  • Got to keep the loonies on the path...
« Reply #79 on: May 11, 2017, 19:51:46 »
I'm late to this party but I'll have some pretzels
