Author Topic: Recurve Bow Build  (Read 4029 times)
Offline trek97
Re: Recurve Bow Build
« Reply #20 on: Mar 06, 2017, 09:57:22 »
Fingers crossed you are able to make the correction.  Its all a learning process, and for me here still cool as fuck, just to see your process!
Michelin Ultra Heavy Duty tubes.  Crazy 4mm thick!  I put one of these in the rear on the 360.  Its almost a tire itself.   Like having a tire inside the tire.
http://www.motosport.com/michelin-ultra-heavy-duty-inner-tube
Kamn
  • Guest
« Reply #21 on: Mar 06, 2017, 09:58:54 »
Very cool!
I say build the inverse of the form and then put a sealed firehose between the two, clamp them together and air it up.
I plan on trying the firehose method in another build but for the next one I do, Im going to use the same form and method.....just improve on it. I have all the materials for another bow but the draw weight will go up to about 45lbs
Kamn
  • Guest
« Reply #22 on: Mar 06, 2017, 10:01:58 »
Unless you need humidity, you can also manage heat with muffin fans.  In the dry boxes I build for ceramics, we want the humidity out, so muffin fans do the trick.  You can also install a dimmer switch.  I've also built them with baseboard heaters as the heat source.  I want 180 to 200 in my dry boxes, and those methods have given me that control.
no humidity needed, but will just get it down to 160. But first Im going to run the oven again with a temp sensor inside to see what its getting up to
Kamn
  • Guest
« Reply #23 on: Mar 06, 2017, 10:02:43 »
Already looking at motorcycle inner tubes since there is motorcycle supply store around the corner from me
Kamn
  • Guest
« Reply #24 on: Mar 07, 2017, 08:03:15 »
Well I got a chance last night to work on trimming the sides down then marking off the tips and cutting them to shape, and thats where I found an issue that makes this bow a Non Shooter, I will not string this bow since I don't want it blowing apart on me and slapping me in the face/head..........this is where this project stops and I'm recollecting to do the next one.
The pic above and below shows the empty areas between the laminations, which I believe is from one of the rubber bands popping and loosing pressure during the cooking phase (some of the rough spots at the edges is just masking tape)
So the plans are in place for the next bow, but the Im making a new form and going with firehose pressure form, I do like the red colour of the Padauk wood so I want to stay with that and I am liking the shape of the bow.....might just make a few changes in the shape of the riser but basically stay with what I have so far
Also, I am going to keep working on this bow as practice for shaping the riser and arrow shelf, but I wont waste material like adding tips.
So Thats its for now, when I start the next one I will do another build thread
« Last Edit: Mar 07, 2017, 08:06:11 by Kamn »
Offline Cookie
  • God help the child who grows out of everything
« Reply #25 on: Mar 07, 2017, 08:13:03 »
So close...next time!
* Insert something witty here *
81 CB750C
84 Tempter - well, most of it...
Kamn
  • Guest
« Reply #26 on: Mar 07, 2017, 08:19:00 »
Next time will be coming soon
Offline trek97
« Reply #27 on: Mar 07, 2017, 18:17:16 »
Dang dude, that stinks.  But I know you'll win in the end.
 keep it going w this thread since we already got it bookmarked for updates when they come.
Kamn
  • Guest
« Reply #28 on: Mar 07, 2017, 19:03:58 »
Trek97,
when I get all the pieces I need to start a new one, I will post it all here
Kamn
  • Guest
« Reply #29 on: Mar 09, 2017, 09:57:18 »
Well, I have started collecting what I need for the next build.
1-1/2" fire hose @ 25 feet for free.....collected it last night
Will need to make some plug ends for it and one side that has nipple to pump it up to 60 psi
