Author Topic: Recurve Bow Build  (Read 4030 times)
Kamn
  • Guest
Re: Recurve Bow Build
« Reply #40 on: Mar 27, 2017, 10:09:24 »
Thought I would post pics of what the this Bow could have been if it had glued up properly. I did some work on the riser for practice before I start my second one.......I will post that one for anyone thats interested in this kind of project
But i  will do another one with this wood combo because I think it would look great with a few coats of clear......also, this is just the rough cut.......I spent a few more hours doing final sanding of which I don't have pics for you
Offline Maritime
« Reply #41 on: Mar 27, 2017, 10:21:05 »
That would have been nice I see why you are going for the combo again.
Offline Cookie
  • God help the child who grows out of everything
« Reply #42 on: Mar 27, 2017, 11:52:12 »
Yeah, do it! That is a beauty!
* Insert something witty here *
81 CB750C
84 Tempter - well, most of it...
Offline trek97
« Reply #43 on: Mar 27, 2017, 14:06:12 »
Gorgeous,  the next one will be awesome w the final finish on it.
Offline trek97
« Reply #44 on: Mar 27, 2017, 14:08:50 »
Are the limbs Big Leaf Western maple?
Kamn
  • Guest
« Reply #45 on: Mar 27, 2017, 14:43:31 »
The limbs are Hard Maple core and Black glass on the back and belly
Kamn
  • Guest
« Reply #46 on: Apr 18, 2017, 08:55:04 »
Update,
So in the meantime of not working on any bikes I did start on a new bow form.
3/4" plywood sandwiching 1/4" ply for a total of 1-3/4"......and you can see the template for the router to cut to shape as well as a new riser that is made of walnut with a cherry core
Then my router went a little crazy because I used 1/8" mdf as the template and the edge started to fold....but I stopped and made 1/4" plywood template and continued then I fixed the chewed up area with bondo and a file
And here is the final product.
The metal frame work does 2 jobs....1 - keeps the 2 halves together at a certain distance  and  2 - also keeps the plywood straight
More to come shortly
« Last Edit: Apr 18, 2017, 09:00:44 by Kamn »
Offline Maritime
« Reply #47 on: Apr 18, 2017, 09:00:37 »
Cool, nice work so far!
Kamn
  • Guest
« Reply #48 on: Apr 18, 2017, 09:18:22 »
As I was working on this riser getting the final shaping done, I screwed up and took a little too much off the lower section...........AND I ended up having to make a new one AGAIN
Old one
New one (walnut with a bamboo core)
So this next part Im going to have to YADA YADA some of the built process because its the same as the first time I posted earlier on in this thread and I also didn't take any pics of the process. Basically mix up the epoxy and coat all the fibreglass and wood cores then lay it into the form and compress it....so here it is
and peeking into the oven while cooking
That was last night and the bow has since come out of the oven and cooled, I just haven't separated the form and removed it.
But maybe later today I will get to that part
Offline JustinLonghorn
« Reply #49 on: Apr 18, 2017, 09:19:21 »
Rad.
Into The Sunset, CB750 build
TT500 the Animal
