Author Topic: CB350 Scrambler Siblings  (Read 12886 times)
Offline ncologerojr
    • Catskill Mtn. Customs
« Reply #20 on: Mar 09, 2017, 19:57:40 »
I forgot to pick up the rubber grommets needed to make the tank mounts today, so I started on the side panels. I roughed in one to check the figment, and I'm really happy with it. I think they're going to look great. I threw on a velocity stack to check the clearances, I'll be running uni filters on the completed bike.
« Last Edit: Mar 13, 2017, 20:34:27 by ncologerojr »
Offline ncologerojr
Re: CB350 Scrambler Siblings
« Reply #21 on: Mar 13, 2017, 20:37:50 »
I hammered out the other three side panels today. I'm really liking these.
Offline ncologerojr
« Reply #22 on: Mar 17, 2017, 12:39:30 »
Backbones seam welded and front tank mounts in place.
Offline 540Nova
« Reply #23 on: Mar 17, 2017, 14:07:12 »
Was that backbone weld to clear your tank or  just wanted something stronger than the factory spot welds?
Offline ncologerojr
« Reply #24 on: Mar 17, 2017, 14:10:59 »
  For both purposes really. It allows me to use a more shallow tunnel in the tank which increases fuel capacity, and it strengthens the backbone. So a win-win as I see it.
Offline canyoncarver
  • 'hacking is learning'
« Reply #25 on: Mar 17, 2017, 16:25:41 »
I always dig your metal work.  Neat dual build !
Offline ncologerojr
« Reply #26 on: Mar 17, 2017, 19:48:18 »
Thanks man!
Offline ncologerojr
« Reply #27 on: Mar 21, 2017, 20:19:38 »
The rear rubber mounts for the tanks are done, and now on to the seat pans.
Offline ncologerojr
« Reply #28 on: Mar 23, 2017, 18:47:05 »
The transition pieces for the set pan are shaped and welded on. There are tabs on the underside that support the transitions and provide weld areas. These pieces allow the seat to clear the rear tank mounts, and provide a sturdy edge for the seat upholstery that will contour to the tank. They actually too a good amount of work, and will be covered in foam and leather, never to be seen again.
Offline ncologerojr
« Reply #29 on: Mar 28, 2017, 23:44:32 »
Before going any further with the seat I wanted to get the side panels mounted. The battery will be mounted below the seat so I decided to make the right side panel removable. I machined some aluminum bullets to hold grommets on the right side panels allowing them to pop off like the stock side covers.
Next I got started on the battery boxes from 16ga steel. I'll mount these up tomorrow.
