Author Topic: YZF750/1000R - The Fly  (Read 43530 times)
Offline Redbird
  • Dolor est Magister Optimus
Re: YZF750/1000R - The Fly
« Reply #360 on: Aug 02, 2018, 22:06:54 »
De Rein ;) :P
When you are Dead, you don't know that you are Dead. It is difficult only for Others.
It is the same when you are Stupid.
Offline canyoncarver
  • 'hacking is learning'
« Reply #361 on: Dec 15, 2018, 16:20:17 »
Haven't ridden this bike much this past summer.  Fixed the water pump and one or two other minor adjustments and it sat a bit while I played with the KLR and the ZRX.  I tried to start it up today and it pissed fuel all over itself.  Probably time to pull the carbs for another look.  I never tried to sync them and I remember they need that too.  I have been collecting new bits and thinking about this sexy beast a lot more lately.
« Reply #362 on: Dec 16, 2018, 22:15:04 »
The new bits.
Its a YEC style cable actuated assembly to replace the hydraulic slave cylinder.  I have the cable and I found a nice lever assembly from an R1 which will let me keep my purple lever.   Enough racers all say it's a better feel on the clutch lever so I wanted one for my build.  This is from Vinco Racing over in the Netherlands.
Offline clem
  • static fluff
« Reply #363 on: Dec 18, 2018, 23:24:55 »
That's the first time I've seen that. There are a lot of cable to hydraulic conversions out there. Interested to hear about the differences first hand.
Sent from my SAMSUNG-SM-G930A using DO THE TON mobile app
« Reply #364 on: Dec 19, 2018, 13:49:23 »
I won't get it on there right away.  I'm elbows deep in Commando stuff right now.  As far as the YZF goes, I may use this setup on the original yzf chassis I got to build into the 1000 beast.
Offline imwastefull
« Reply #365 on: Dec 19, 2018, 14:55:52 »
You mean like this?
Is that your FXR?
« Reply #366 on: Dec 19, 2018, 15:15:34 »
Is that your FXR?
Yep, I have a shovelhead chopper too.  I like bikes.
« Reply #367 on: Feb 11, 2019, 00:27:58 »
I fired up the YZF today to see how it would wake up.  It took some ether but once running, carb 3 was pissing fuel out of the float bowl gasket so off they came.  I have a new set of oem bowl gaskets on the way and I'll give them a good cleaning while they are off.   I never did get around to syncing them last summer.  They are a pain because there aren't air nipples on the 1994' version of the intake manifolds.  I bought a set from a 97' awhile back but never got around to putting them so I got them installed today with fresh oem gaskets.  4 nipples.  It'll be much easier to get the sync hoses setup now.   I've got a set of the hoses on one of my parts bikes.
Offline Sonreir
  • Moderator
  • Oregon
« Reply #368 on: Feb 11, 2019, 11:19:48 »
Ugh. Carb work...
Audaces fortuna iuvat.
Suzi T500 Cobra Resto
Custom Gauge Graphics
Custom Wiring Harnesses
« Reply #369 on: Feb 11, 2019, 11:43:01 »
Ugh. Carb work...
Agreed.  Not my favorite and these are known to be a bit finicky.
« Last Edit: Feb 11, 2019, 11:51:27 by canyoncarver »
