Author Topic: YZF750/1000R - The Fly  (Read 48243 times)
Offline furu14
Re: YZF750/1000R - The Fly
« Reply #80 on: Apr 22, 2017, 17:05:28 »
As long as you have a feedheight of a foot or 2 your good. ;)
only reason for the pump is the high mount of the carbs relative to the tank.
Offline canyoncarver
  • 'hacking is learning'
« Reply #81 on: Apr 22, 2017, 17:33:37 »
Excellent, I was figuring/hoping so.  Thanks!
« Reply #82 on: Apr 23, 2017, 19:36:10 »
Today was messy.  Trying to put together one pair of rear sets but need a new shift lever.  Got a good clutch master cylinder together and figured out which front brake master I'll use but need new levers.   HEL brake and clutch lines on order.  Some more carb parts on order too.    I started chemically stripping the tank to see what I have.  Failing liner in the tank.  I'm going to call around and see if a radiator shop can dip this thing.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #83 on: Apr 23, 2017, 22:05:10 »
I had a hard time finding anyone to mess with fuel tanks. Ended up doing it myself both times. MEK strips red-kote pretty easy, might break down a couple other liners as well.
Offline hillsy
« Reply #84 on: Apr 23, 2017, 22:58:57 »
The good thing about the YZF tanks is there is a massive plate underneath you remove to get the fuel pump out. Makes it easy to get in there and remove any crud.
« Reply #85 on: Apr 23, 2017, 23:33:57 »
Heck yes it does. First tank I've had like this. It should make it easier when I have to re-coat it too.
I also found a pinhole in the top of the tank.  Looks like it should be an easy fix.  Doesn't look rotted and there was no dents under the paint.
« Last Edit: Apr 23, 2017, 23:38:18 by canyoncarver »
« Reply #86 on: Apr 23, 2017, 23:35:27 »
I haven't used MEK before but it's cheap at Home Depot.
Offline advCo
  • Nick Ol' Eye
    • adventur Studios
« Reply #87 on: Apr 23, 2017, 23:59:18 »
Its NASTY stuff, be sure to use it outside and a fan/respirator and some long gloves come in handy
Offline Drewski
  • "Invictus Maneo" - I remain unvanquished!
« Reply #88 on: Apr 28, 2017, 20:25:35 »
+1!! It's a killer!  :o
Be careful.  :)
The Kawasaki Line-Up:
"Keepin' the Good Times Rolling"
STREET:
'77 "Faux" z1 kz/zx10r "Resto-Mod" BOTM
PLAY:
'72 kv75 "Pitbike" 4 Sale
TRACK:
'81 GPz/kz550 "TrackBike"
ON THE WORK BENCH:
SeaGlider's '71 h1a/750 "FBG Sleeper"
Drewski's '74 h2b Tracy/zrx Project
FOR SALE/GONE:
'05 zx10r "RetroLookRacer"
'02 zrx1200r "DailyRider" SOLD & GONE!!
'99 zrx1100 "euro-style" SOLD & GONE!!
'75 s1-250 Triple "Survivor" SOLD & GONE!!
'74 h2b/FZ "Mongrel" BOTM, SOLD & GONE!!
« Reply #89 on: May 02, 2017, 12:54:00 »
So....I received the hydrasonic cleaner and it was bad.  I filled it up and turned it on only to hear a crazy noise like it was going to explode and electrocute everything nearby.  Definitely not working so I shipped it back this morning.  Pisser.
