Author Topic: YZF750/1000R - The Fly  (Read 48192 times)
Offline 1fasgsxr
Re: YZF750/1000R - The Fly
« Reply #210 on: Feb 19, 2018, 13:09:01 »
I forgot that thing has 3 intake valves per cylinder...  ???
Offline beachcomber
  • TJ - Beachcomber
« Reply #211 on: Feb 20, 2018, 08:49:56 »
Nice work CC ............. nice whisky ! ;)
Offline canyoncarver
  • 'hacking is learning'
« Reply #212 on: Feb 20, 2018, 12:27:10 »
Yep.  It has it's own sound at WOT that I love.  All in all, not much different doing it on this than an older air cooled Kawasaki shim under bucket other than all the stuff you have to remove just to get to the heads.
« Reply #213 on: Feb 20, 2018, 12:28:49 »
Thanks BC.   Just enough to keep me going but not enough to get sloppy.
Offline fortysixand2
« Reply #214 on: Feb 22, 2018, 03:51:28 »
Very cool build, should be a rocket! *follow*
« Reply #215 on: Feb 23, 2018, 16:53:06 »
Cool!
« Reply #216 on: Feb 23, 2018, 16:56:20 »
New Yamaha clutch is happening.  Did a full strip and rebuild on the clutch master and slave as well as finally installing the braided stainless clutch line.  I also scored a nice (but varnished) set of yzf carbs for cheap.  78$ shipped.  Better than the set that came on the parts bike.
« Reply #217 on: Feb 26, 2018, 14:28:07 »
Clutch is all done.  I'm waiting until it's off the lift and on its wheels to finish routing the new ss line to the clutch master cylinder so I can check it at full turn stops.  Rear wheel is off for a new tire.  Front will get one when the bikes is off the lift.  I'm also doing some harness cleanup in the front around the radiator.  Nothing was messed with, just age related stuff.
Offline trek97
« Reply #218 on: Feb 26, 2018, 21:58:19 »
Holy cow.  I just found this thread.    :o
« Reply #219 on: Feb 27, 2018, 12:15:58 »
Yessir, here to stay.  "estamos aquí por la cerveza"
« Last Edit: Feb 27, 2018, 12:20:33 by canyoncarver »
